Question about Dell Computers & Internet
I have this westpoint dvd player everything works except the sound when watching a video
SOURCE: XOVISION CAR DVD PLAYER SOUND NO PICTURE
hook your brake line wire from stero to your ground wire. it needs to be grounded
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: XOD1736
This is a problem with break wire. I too expierienced this. It is NOT a problem with radio. You need to ground the break wire in the harness. It is a protection wire so that it knows the emergency break is on. In other words it is supposed to stop you from watching movies while driving. Grounding the wire disbales the feature thinking the break is on. If you want to use the safety feature properly it should be connected to the emergency break switch that is grounded when pulled up or on.
Posted on Apr 06, 2009
adnanbhatti
  • 1188 Answers
SOURCE: Dell Latitude D610 dvd player won't work
Try a CD ROM lens cleaner. If it fails then I suggest you buy a new one. It is easy to change it: there is a release switch at the bottom with a screw. Open it and remove the old one. Slide the new one into its place.
Posted on Aug 05, 2009
  • 630 Answers
SOURCE: toshiba sd-k970 dvd player sound but no video.
I presume that you've selected the correct inputs on the TV? Go for HDMI if you have it on your TV. If not use the yellow (composite) and ensure you have nothing in the S-Video (Toshs don't like using composite and S-video at the same time).
Posted on Aug 30, 2009
Sandyrain
  • 74 Answers
SOURCE: convert jvc videos into playable dvd on a standalone dvd player
Hey! I recommend you use this DVD Converter studio, by wich you can convert your jvc enverio videos into movies so that you can watch them on your dvd player. Hope that helps.
Posted on Sep 02, 2009
Hi ive got an eonon e1012 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i put in a cd...
hi, i bought eonon E1012 on Eonon official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.
I think maybe you have connect the wrong wire and have bum out the built in amp.
Nov 08, 2009 | XO Vision XO9013 Car DVD Player
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
No sound. checked the fuse.
Sounds like the output section of the amp is toast. Especially if there was smoke involved.
Mar 03, 2009 | Pioneer AVH-P6600DVD Car DVD Player
Dec 30, 2008 | XO Vision XOD1735 Car DVD Player
Clarion vrx755vd no sound
i have the same problem and apparently it is the microprocessor (the brain of the system) is burnt out.
Mar 10, 2008 | Clarion VRX935VD Car DVD Player
DVD picture is black and white
Sounds like you are either trying to play an NTSC (US or Asian) DVD on a PAL (European) TV.
Go into the DVD settings and look for picture, video or display options.
If the DVD is set to NTSC, then set to PAL.
Jan 06, 2008 | Philips DVD 622 DVD Player
Phillips Home Theatre System
Did you try un-plugging all cords, turning off power to that circuit, or indivisually disconnecting all electrical cords from each component that has no sound emmitting from it. This procedures sometime or some how reboots the audio or video component to its original setting. Good luck Sir.
D. White
Nov 13, 2007 | Televison & Video
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
