Question about AT&T UVerse
Unable to get remote to recordings or menu - AT&T UVerse
    Problem Solver:
  • 16 Answers
Hi.
the only reason why these functions are not working is because your Remote control is on TV mode. The best way to resolve it is by Pressing the ATT button on the upper left hand corner of your remote and all functions will work..
I hope this helps you and please don't forget to rate me.
Thank you.. :)
Posted on Sep 22, 2014
Unable to perform initial settings
Manually select MENU or SETUP on the remote.
Dec 28, 2012 | Toshiba Dr430ku Dvd Recorder - Black
I have a Sylvania DVD Recorder/VCR. The DVD Recorder records in SP mode only. How do i change the Recording mode to something other than SP?
There should be a speed button on the remote or a similar button if you are just hitting the record button on the remote to start the recording. You can change it after you start recording. Otherwise if you are setting the record time in the menu itself, then the option is in the menu. If you are still unable to figure this out, please give me the model number of both the player and remote that you are using and I can tell you what to press exactly.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Televison & Video
Panasonic dmrez27 dvd recorder stuck on dvd2 setting
If you point the remote towards sensor, simultaneously hold down the number (1, 2, etc) you want AND the enter button for 5 or more seconds it should switch to the number pressed. Remember if you have a second one, make sure it's off or put towel over its remote sensor. Sue
Feb 20, 2010 | Panasonic DMREZ27 DVD Recorder
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
DMR-ES46V "set 1" error message
Hi, All you need to do is point the remote at your DVD player and hold both the number "1" and "enter" keys down for about 10 seconds. Evidently that re-sets the remote. It worked for me so good luck.
Pete
Oct 06, 2008 | Panasonic DMR-ES35VS
Orion VR213
Call the number on the unit to price an original remote.
Jul 23, 2008 | Orion VR213 VHS VCR
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Sylvania SRD4900 DVD/VCR combo problem
Hi I am Temperance MI and I see this mode in my shop often, does any onscreen menu come up when using the remote and
going into menu? If not maybe the remote is bad, common just
a loose battery lead, If you are able to go into menu, and set the
clock, but unable to set timer record, look closely at you recordable tape to make sure on the left bottom from corner the
the recording tab is in place, You can place scotch tape over this hole of existing tab to ensure it will go into record. Finally
if it wont go into record when you try to use OTR, you
make a problem with the record ready switch in the VCR section. Joe . East Electronics, Temperance MI
Jan 23, 2008 | Durabrand DUR7 Portable DVD Player
Programming my mitsubishi remote
If the remote is specific for your model of Mits (or a range of Mits models) it should be able to do every function including time/date/timer record. If by chance this is a universal remote box (it doesn't look so by the part number you supplied), many such boxes- especially lower cost ones, may not be able to do those advanced functions. Your remote box should have a menu button which will allow you to access all the setup areas. One site shows your remote http://www.replacementremotes.com/store/prodthumbs.cfm?sr=101&CATEGORYID=289 and there is a menu button on it. It is possible the remote box has a problem (well used boxes can have buttons which fail to work, or are difficult to activate. Did you purchase these new, or used? If used, then perhaps a dead or difficult button is a fair possibility. If this is the problem, sometimes this can be fixed or improved by taking the box apart and cleaning the button pad and matching contact surfaces on the circuit board.
Oct 03, 2007 | Televison & Video
AT&T UVerse Logo
37 people viewed this question
Top AT&T Televison & Video Experts
Stan Skaggs
Stan Skaggs
Are you an AT&T Televison and Video Expert? Answer questions, earn points and help others
