How to avoid sounds heard in speaker even after connecting headphone in compaq presario c700
Asalam u alikum,
Dear friend yours broblem have been solved if you do this steps.
1. first go to the start menu.
2. then select a control panel.
3. In control panel select option (sound,speech,audio devices) then select change the speaker setting, the sound and audio properties is opened, go to the speaker setting select advanced option in advanced option change the speaker setup and select stereo headphone and apply it.
I hope its solved yours problem.
Thanks
Do you have sigmatel audio or realtek?
Can you check the control panel for the "soundcard control panel" and locate a place called "jack setup" which tells you what the computer sees in those jacks?
Lastly, can you try with a different headphone?
