Question about Konica Minolta Office Equipment & Supplies
Error code c0f32 model biz180 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Replace the developer and the drum also ensure counters are cleared and F8 is run after installing new develope and drum.
Posted on Jan 10, 2016
wheatlandsvc
  • 1110 Answers
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
Posted on Oct 27, 2009
SOURCE: Getting error C0f32
HOLA BUENO YO TENGO 2 MAQUINA MINOLTA 2510,3010 ME GUSTARIA SABER LOS CODIGOS DE AVERIA POR FAVOR LES AGRADECERIA MUCHISIMO .
Posted on Nov 18, 2009
randula7
  • 78 Answers
SOURCE: minolta di20 c0f32 error?
C0F32 Faulty ATDC Sensor E1
The value of data read by E1 is faulty. [E1 reading is 7% or
less (3.92V or more) or 19% or more (1.41V or less).]
C0F32, C0F33
Are PJ40, CN50, CN17, and PWBA
PJ15A connected properly? Connect them properly.
Is the CN50 connection dirty? Clean
Is “C0F32” or “C0F33” displayed
even when an I/C with the same T/
C as that of a new one has been
installed? Change the I/C with a new one
installed and an F8 operation run?
(Be sure to record the ATDC control
voltage setting value if an F8 operation
is to be run.)
YES Change PWB-A, install the old I/C,
and return the ATDC control voltage
setting to the value recorded. If
“C0F32” or “C0F33” redisplayed,
change the I/C with a new one.
is to be run.)
NO Change the I/C with a new one.
Posted on Jan 26, 2010
Bizhubman
  • 108 Answers
SOURCE: how to fix error c0f32
Faulty TCR Sensor
• The measurement taken by the TCR sensor (TSRS) at a
time 2.0 sec. after the main motor (M1) has started turning
is less than 5% (greater than 4.63 V).
• The measurement taken by the TCR sensor (TCRS) at a
is 19% or more (1.41 V or less).
I would start with checking the TCR sensor located on the developing unit. Make sure it isn't caked up with toner. After that I would replace the developer and then the sensor. Check the developer unit for any damage to gears and seals.
Posted on May 17, 2010
SOURCE: how to solve bizhub 211 code error c0650
C0650
Faulty scanner home
position sensor
• The scanner home position sensor (PS100) does not go
from HIGH to LOW when the scanner motor (M4) is energized
for a given number of steps after the sequence to
bring the scanner back to its home position has been
started at the end of a scan motion and during re-shading.
from LOW to HIGH when the scanner motor (M4) is energized
for a given number of steps after a scan motion has
been started at the end of a PS100 home check scan
Posted on Dec 07, 2011
How to clear error code c0f32 problems by minolta Di152
replace the developer and drum , clear counter and run F8
Mar 24, 2015 | Konica Minolta Bizhub 180 Di 152 152f...
Konica minolta b163 has this code cof32, how to take it out?
Hi
I have found your problem here:
Error Codes Konica Minolta bizhub 163 Code C0F32
and it says:-
Code:- C0F32
Description:- Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Remedy:- 1 Check to see if developer is available. 2 Check the ATDC Sensor connectors for proper connection and correct as necessary. 3 Change UN1. 4 Run ?gATDC Auto Adjust. 5 Change PWB-A. 6 Change PU1.
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Konica Minolta Office Equipment & Supplies
How can i solve error code C0F32 in konica miniolta 7118
Press [Utility] -> [Stop] -> [0] -> [0] -> [Stop] -> [0] -> [1]. Go to [Adjustment] --> [ ATDC Adj. ] [Start], wait for 2 mins. it will automatically stop then turn Off / On copier. If C0F32 appear replaced the ATDC sensor located under the developing unit then calibrate again.
Oct 16, 2014 | Konica Minolta Konica 7115 7118 Compatible...
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
How to clear error code C0F32
by khan
Jan 16, 2011 | Minolta Di3510 Fax
Minolta di20 c0f32 error?
C0F32, C0F33
is to be run.)
is to be run.)
Jan 25, 2010 | Minolta Office Equipment & Supplies
Oct 27, 2009 | Konica Minolta Office Equipment & Supplies
C0F32 error displayed in new machine just in 25000 copies
Is the copier is brand new out of the box? If so you have to call a dealer or a good friend that works on them to help you by pass the set-up error code. They put that little curve in to stop none dealer from installing there copiers.. Good Luck......
Jul 29, 2009 | Konica Minolta DiALTA Di200 Copier
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
