Zoostorm PC cannot detect wdmybook
Good morning I have set up my new Zoostorm pc and tried to make connections to two separate external network drives that I have purchased. The first network drive which I connected through my broadband connection, could not been located on the pc. I involved my Technical Computer advisor and he spent 4 hours checking all the settings and tried the unit at his home using the same broadband connection. He concluded that the unit was faulty and I returned the unit for refund. I purchased and installed a WD Live Duo external network drive. The pc could not at first find the drive. After support from WD the drive could be seen on My Computer but when the WDSmartware was run and the dashboard displayed for a back up process the WD drive was not shown. Over five days WD Support has checked all the settings and connections that they believe could be an issue and still the WDSmartware cannot detect the drive. I installed the WDSmartware on my laptop and the drive is displayed in the dashboard ready for a backup to be made. The conclusion is that as the WD network drive is working on the laptop then there must be an issue with the pc. The pc was purchased through Amazon with Windows 7 Home edition installed. Windows back up is not available on the Home edition. Do you have any experience of network drives not working on Zoostorm pc's? Do you have any advice on any settings to be checked/changed or other action that can be taken to operate a backup. David Hillman
fire sine
  • 382 Answers
SOURCE: adding an external hard drive to a home wireless network
Try setting configuring the privledges setting. Make sure there the network setting is correct, and make sure all user accounts have admin access to network
Posted on Oct 22, 2007
SOURCE: Failed to detect an internet connection
if you are having problems with your Linksys routers, reset the router and configure it again. In configuring the router, I suggest that you use the online tool that will automatically configure your router. It is similar with the setup cd but the online tool works better. The reason why the setup cd fails is that it has its own bugs. So just use the online tool. You can get the online tool on this website--www.linksys.com/easy.
Posted on Dec 21, 2007
ginko
  • 19396 Answers
SOURCE: External USB Drives No Longer Detected
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Posted on May 04, 2009
  • 218 Answers
SOURCE: 3 failed attempts to connect HP DV6t laptop
Check this Linksys FAQ website:
http://www.linksysbycisco.com/US/en/support/WRT310N
Posted on Jan 03, 2010
  • 36 Answers
SOURCE: smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
Posted on Mar 11, 2010
Zoostorm
plz go to device manager in control panel and reinstall the sound card....just delete the sound card and refresh may be it will ask for driver so put the cd in the drive which comes with the computer..hope solve ur problem
May 15, 2014 | Computers & Internet
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
How to wirelessly connect zoostorm G530
The USB one should work. The computer should detect it and automatically install the driver. If you have a disk with it try that. Once the computer has installed the adapter you need to wirelessly connect it. The old school way is to see your router in the listed stations, click on it and then supply the correct key. The new way of doing it is to use the magic button on the router itself which unlocks it for 2 minutes. Then when you click on the router listed it just lets you in.
Oct 22, 2017 | Computers & Internet
My phone doesnt detect its memory card but when i connect it to pc ,, my pc detects memory card but my mobile does not???? Phone: videocon V1422
The problem is, that you type of phone can only handle a maximum of 2 gigs.
When you connect it to your PC it detects it, because the PC uses them (phone and sd), like two separate drives, and that's because when there is SD -> Phone -> USB cable -> PC, the uses the as a simple "cable".
So unfortunately you will have to buy a 2 gigs SD.
Dec 29, 2010 | SanDisk 4GB microSDHC Memory Card
New internet explorer no internet connection
Adding a browser should not effect your internet access.
Do you still have your old browser?
Does it work?
Have you accessed your network connections and checked to see the
condition of your connection?
Did you configure your browser to work on your connection?
--On your browser click TOOLS and go to internet options.
--Check the CONNECTIONS tab
--Click LAN SETTINGS
--Check the box that says "automatically detect settings"
--Uncheck any other box.
If this does not work, u need to provide more info about your network settings.
Mar 16, 2010 | ASUS Eee PC 1000H Laptop
I cant open a browser the network is connected
Try this:
Control Panel>Internet Options>Connections Tab>LAN Setting tab -- Make sure the Automatically detect settings is selected and nothing else. Select OK to back out of all windows and retry your connection.
Good Luck
C2Solutions
Feb 10, 2010 | HP Pavilion a1610n PC Desktop
No network
if you are on a wifi zone it must be detected by your laptop if not maybe your network connection setting for detecting wifi is off. try changing the settings of your network connection. and change it to auto detect the network connections
Aug 10, 2009 | Sony VAIO GRZ610 Notebook
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
