Question about Hobart Dishwashers
Replacing rinse area baffle part #936185 on hobart cl64e
Causes of low rinse water pressure on a Hobart ft900-d washer
For a machine without a break-tank (a.k.a. cistern) and booster pump: check the inline debris strainer on the rinse water pipework; check you're not missing any rinse jets; check the inlet valve is fully opening.
For a boosted machine, check the pump impeller isn't disintegrating; check that the flexible hoses to the booster pump aren't collapsing internally.
For both machines: descale if you're in a hard water area.
Mar 15, 2015 | Hobart Dishwashers
My lxi-h won't draw rinse aid through the pump
You need to replace the squeeze tube on the rinse aid pump
May 23, 2013 | Hobart Undercounter/Lxi Warewasher 24"W x...
I have a am-14 hobart washer. having problem with rinse temp indicator. it is fine for the wash then the temp gauge is jumping around, could it be the thermostat?
Your rinse temperature sensor that is a tiny probe in the water piping (top rear of machine) needs replaced. Hobart part # 00-294692. It costs about $84.
Oct 19, 2012 | Hobart Dishwasher Am-14 Commercial Dish...
Hobart LXI-H rinse doesn't work
water flow pressure needs to be a min. of 15 PSI..
Apr 26, 2012 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Good morning, I have 01 Hobart dishwasher AM14, i need to be replace rinse sensor probe and temperature sensor for booster heater.But I can't to find Hobart part number Please help me.Thank you.
294692 for the rinse probe.
"temperature sensor for booster heater"? Do you mean the thermostat? If so, part number is 274161.
Parts breakdowns and part numbers are available at www.hobartservice.com. Click "Parts" on the left, then click "Hobart SmartParts System" on the next page. You'll be asked a series of questions to identify your piece of equipment, and then you'll get a parts list and have links to parts breakdowns for various sections of the machine.
Nov 20, 2010 | Hobart AM14C-155 Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
Error code "p3" appears in the digital panel with a little tool diagram. The rinse cycle doesn't work..
That code is for the booster . probably the thermistor .. if there is a hobart service center in your area, you could get one there and instructions on how to replace.
Please vote!
May 12, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart AM-14
is this a Hobart chemical system or other? call your chemacle people who service you. also make sure you are even rinsing. at end of rinse watch light on door raise door and take sample off of arm where water should still be draining out from rinsing
Aug 09, 2008 | Hobart AM14-253 Free-standing Dishwasher
Dishwashers Logo
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
