Question about Presto HeatDish Compact Heater
Ajustment knob hard to turn - Presto HeatDish Compact Heater
How to chage or ajust a gear knob of a z4 2003
pull up and use excessive force! it just struck not bolted
Atention where is it go..... damaged Your knock out knob on face
Jun 26, 2010 | 2004 BMW Z4
If I turn the gas burner on above medium, it clicks and never stops clicking until I turn it down or off.
you may be turning it up unlil it lights. Try taking off one of the knobs and turn it over and look inside Many stoves have two little ajusting screws insind with instructions andthe adjustment resets the knob
positioning on the valve stem. try that.
Apr 21, 2010 | Wolf Range CHR-10-229-FT11 Kitchen Range
I have a 25hp evanrude (1994)tiller steer,would like to ask if the knob at the end of the tiller is for the slow running mixture,if so how is it ajusted as my motor runs ok at speed but mucks up at low...
this knob is a low idle stop
loosen the knob set the throttle to slow but running ok then tighten the knob
now the throttle will not go lower than this set point and die out
hope this helps
Apr 22, 2009 | Boating
Turn up pilot light
The ajustment screw to increase the intensity of the piolet flame is located on the oven gas valve(behind the cntrol knob.
Apr 04, 2009 | General Electric Stove/Oven/Range Chrome...
Help on ajusting the speakers
If you have the factory stereo, push in the power button with the stereo on, and then turn it to adjust the balance between left and right. Then you can return it to the normal position. Then PULL out the same knob and when you turn it you will adjust the "fade" between front and rear speakers.
Mar 27, 2009 | 1991 Volvo 740
Older gas range not heating up enough
Pull the knob off of the oven control and see if their is an ajustment. If the ajustment doesn't work then change the thermostat bulb. It goes for the oven to the back of the oven control know
Dec 21, 2008 | Ovens
My ventless gas heater has an uneven flame with orange tips, the flame toward the outer edge is higher than the flame in the middle, and also,when I light the heater, it doesn't just give me a piolot...
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Oct 24, 2008 | Heating & Cooling
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
Presto HeatDish Compact Heater Logo
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
