Question about Apple MacBook Mac Notebook
Eject command for macbook pro - Apple MacBook Mac Notebook
    Master:
  • Apple Master
  • 545 Answers
The eject button is at the top right of the keyboard, but you may also drag to the recycle bin and it will eject.
Posted on Jul 18, 2014
2 Suggested Answers
  • 53 Answers
SOURCE: MacBook Pro intel, CD stuck not mounting or ejecting
while restarting, push and hold your mouse button during the entire boot sequence. this will force the ejection of the cd.
Posted on Jun 04, 2009
How to i eject a disk from my mac computer
I'm thinking it is working normally, so you can either:
1) Select the disk (or open a folder inside that disk) and press Command+E and that should EJECT the disk.
2) Drag the disk to the trash
If the computer is not ejecting the disk after that then you have a problem with the hardware. The next step would be trying to eject it while restarting.
Oct 28, 2014 | Apple MacBook Pro Notebook
How do you force eject a disc from a macbook pro?
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
Aug 14, 2014 | Apple MacBook Pro Laptop Computer with...
How do I eject a DVD from the MacBook Pro?
Press the eject button on the keyboard, top right-hand side, just above delete button.
You could also try going to your HDD, click on CD Drive, right click and eject.
Hope this helps.
Feb 07, 2014 | Apple MacBook Pro Notebook
Dont know where eject button is
upper right of the keyboard. If you drag the icon towards the recycle bin, it will turn into an eject, if it is a disk.
Feb 03, 2014 | Apple MacBook Pro Laptop Computer with...
CD won't eject from MacBook Pro
Keep the eject button held down on switch-on.
Otherwise you'll have to have the drive dismantled.
Jul 27, 2011 | Apple MacBook Pro Laptop Computer with...
My daughter put a small disc for her music in my mac computer how do i get it out
4. Press COMMAND-E.
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.Alternatively follow the following instructions: How do remove stuck Mini CD from the SuperDrive on Macbook Pro
Dec 29, 2010 | Apple iMac OS 9.1
I have macpro 13inc.my problem is my disc is not working with the eject is not function.so still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- CD DVD EJECT -
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
-EJECTING DISC USING TERMINAL-
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
-Mactechtrainer
Aug 26, 2010 | Apple MacBook Pro Notebook
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
My Macbook Pro (Intel) will no eject the CD. Finder and disc manager don't show it, holding down the track button whilst rebooting doesn't work, there is not a little hole to push paper clip into. Is...
1. Restart the computer. If necessary, use the reset/interrupt button.
2. Immediately after the system startup tone, press and hold the Command-Option-O-F key combination. The computer starts up to a text-only screen, indicating that you are in Open Firmware.
3. At the prompt, type: eject cd
4. Press Return.
5. Type: mac-boot
6. Press Return
Sep 25, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Mac Notebook Logo
46 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
