Question about Sharp Aquos Televison & Video
SHARP flat-screen TV automatically shut down and turn on
  • 298 Answers
SOURCE: VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Posted on Feb 25, 2008
  • 103 Answers
SOURCE: Sharp 42" flat screen LCD T.V.
You have a bad buffer ic,which is part of the lcd panel.Definiately call sharp to get it repaired.If it doesn't have a warranty,persistence through sharp will get you results.
Posted on Mar 07, 2008
james klgr
  • 362 Answers
SOURCE: turns on and off automatically
getting hot and shutting down try to clean it out could be very dusty inside
Posted on Jun 21, 2009
  • 14 Answers
SOURCE: TV automatically shuts of at 1hr.
replace D10 on power supply board near large capacitor (100uf 450V)
Posted on Jun 23, 2009
SOURCE: Sharp LCD flat screen TV turns on with a grey screen
Whats happening is that the TV' sets of today are really PC's dedicated to a TV tuner..sort of.. As such, well PC's, hang up, get into "Loops" and the like. Also as such they need to be "Reset" to clear any faults, now sometime the circuit called the P.O.R. "Power On Reset", well, it doesn't... and it often takes a couple of "Reboots" to clear the "Fault".
Posted on Feb 04, 2010
Testimonial: "Thank You"
How to reset a sharp aquos lc4d62u without a remote
You can use the 'menu' button on the panel (next to power on my model) to bring up the 'Initial Setup' screen. The factory reset option is available from that menu. You'll need to navigate through the menus using the channel up down buttons and the enter button on the front of the TV.
Oct 14, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
Sharp LC-32LE240M automatically shuts down
It should have come with a one year parts and labor warranty so consider looking into getting it fixed under the warranty--opening set or tampering inside would void the warranty.
Dec 19, 2012 | Televison & Video
I have a Sharp Aquos TV that started to turn on but shut off automatically. Tried it several times and it kept doing the same thing. Now the tv won't even turn on and the power light on the tv keeps...
It sounds like a bad capacitor. If you are handy, you can search on Youtube on how to replace them on your model. If not, have a proffesional look at it. The individual parts should be inexpensive. The service charge varies. Good luck!
Aug 30, 2011 | Sharp Televison & Video
Our 32" flat screen 2
Please replace power supply board in tv to solve its problem.
Required power supply board is available in shopjimmy.com under $100 and local tech will replace it.
Thanks.
Apr 21, 2011 | Sharp Televison & Video
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Is there a reset button on the 27 inch sharp aqua tv?
  • Press "Menu" on the TV's remote control and use the arrow keys to scroll to "Setup."
  • Scroll down to "Reset" and press "Enter" on the remote.
  • Select "Yes" using the arrow and "Enter" buttons at the "Return To The Factory Preset Values" message.
  • Select "Yes" using the arrow and "Enter" buttons at the "Now, TV Will Restart Automatically. OK?" message.
  • Wait while "Now Initializing..." appears on the screen. The TV will power down and turn back on when the reset is complete.
  • Read more: How to Reset a Sharp Aquos ' eHow.com http://www.ehow.com/how_7225301_reset-sharp-aquos.html#ixzz12i633RwM
    Oct 18, 2010 | Sharp Televison & Video
    Sharp LC-52SE94U shuts down and restarts automatically
    There is a software update for this model via the Sharp website. Included is a link to the compressed folder. Once you uncompressed the folder there are instructions in the folder on how to install the update. It doesn't specifically say this is a fix but as a TV technician personally its the fist thing I would try.
    Link to Sharp software update
    Nov 17, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
    Turns on and off automatically
    Jun 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
    Televison & Video Logo
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
