Question about Canon Laser Class 830i Plain Paper Fax
Clear memory on a 830i - Canon Laser Class 830i Plain Paper Fax
How to program TX report on a canon laser class 830i
You can find instruction on how to configure Transmission Reports on page 364 of the use guide. (see below)
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
Hope that helps.
Dec 19, 2014 | Canon Office Equipment & Supplies
I am getting a feeder glass dirty message. I have cleaned glass and rollers. Do I need to reset
look the cartridge is there some defect.and then do the reset.Its not anything big failure just the printer sometimes mix the right info.
Jun 05, 2014 | Canon Laser Class 830i Plain Paper Fax
Can't receive large faxes
This is not a UK model but the same principles apply. When you receive a fax it is stored in the memory until the whole page is received, then it will start to print. The memory is not split so if you have a lot of faxes to transmit stored in the memory, they will gobble up the memory and reduce the size for receptions to be stored in. Check to see what is stored and delete them to free up memory. If this does not resolve the issue then the machines memory will need to be cleared by the service mode. As I don't know the UK version I cant advise any further.
Mar 12, 2014 | Canon Laser Class 830i Plain Paper Fax
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
Can't find a manual for vodafone 830i mobile phone
vodafone only sends settings itself. u need to ask customer care for settings. manual settings are however present in vodafone.in website
Nov 11, 2009 | Cell Phones
Red crossed horizontal icon flashes on screen
It's the warning to replace the backup battery which is housed behind the main battery.
May 28, 2009 | Canon MV830 Mini DV Digital Camcorder
Canon Laser Class 830i Plain Paper Fax Logo
22 people viewed this question
old marine
old marine
