Question about Kenmore Dryers
Need to convert my Kenmore HE3 from propane to natural gas
Kenmore he3 model number 110.94832201
3 Suggested Answers
  • 91 Answers
SOURCE: How do i switch from propane to natural gas on a
You would have to change the gas train out to a natural gas one, the orifice sizes are different.
Posted on May 02, 2011
MNTECH
  • 1543 Answers
SOURCE: Need to convert from natural gas to propane
Take 3 screws out of bottom side of Z shaped metal part on the back of the dryer's top. Stand in front of dryer and use the palms of your hands to sharply push dryer top back about 2 inches and lift top off. Open door and remove screw at 4 and 8 O'Clock position. Remove control panel (ususally 2 screws and a bunch on retaining plastic parts along the top side) and set on top of dryer or unplug electrical plugs and set aside. Remove screws at top of front panel. Unplug light bulb and door switch. Tilt front panel forward and lift off bottom tabs, then unplug moisure sensor wire at bottom, allowing front panel to be set aside. Remove 4 screws at sides of drum support assembly, lift up and off. Release belt, and remove drum. (easier to do if flat metal part originally right behind control panel is removed first) Use belt as a handle and lift drum out of dryer, allowing access to burner assembly. Change burner orfice and regulator blocker. Re-assemble and test.
Posted on Nov 18, 2011
Have Kenmore elite dryer. How do you get into it to convert from LP to natural gas?
most require a kit to change from 1 type gas to the other . they have to come in thru the back someplace
Feb 09, 2015 | Kenmore Elite HE3 Steam 8674 Dryer
Converted a kemore from gas to propane now it doesnt get very hot and takes forever to dry
Normally natural gas appliances have a different nozzle size than the propane units. i would check with your propane/gas dealer to make sure.
Mar 02, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Can i convert kenmore 700 from natural gas to propane? what do i need to do? thanks!
Go here
key in the complete model number and see if there is a kit for that or if you even need a kit to convert it..
heatman101
Jul 12, 2011 | Kenmore Dryers
How do i switch from propane to natural gas on a Kenmore he3 Dryer
May 02, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore He3 washer manual required
Head over to the manufacture's website. WWW.SEARSPARTSDIRECT.COM
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Dryers Logo
16 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
