Question about XFX NVIDIA GeForce 8600 Graphics Card
My PC goes to standby mode while turning ON.... I have to again turn off and on the UPS amd cpu in order to start the PC .... Does any have have d solution for this........
  • 85 Answers
Make sure that the UPS is working with 100% voltage. this prob is common and it creats from Voltage problum.\
good luck
shakfy
Posted on Jun 19, 2009
I have HP G60 Laptop with AMD turianX2. It gets heated up during Video viewing for more than 15vto 20 mts and also during skype cat or you tube video display. The display suddenly gets blanc, voice sound...
Not sure if you can fix it, but it's an overheating issue. Laptop overheats and shuts down itself in order to cool down. You state it's a turion CPU and those are OLD. During all those years your laptop was sucking the air from below and blowing it out so dust particles and some other stuff has clogged your vents. Soulution to your problem would be to take the laptop apart, take of the cpu cooler, blow it out with an air compressor or vacuum cleaner, apply some new thermal paste to the cpu and add the cooler again. If you feel uncomfortable doing that - get it to the nearest repair center.
Mar 12, 2012 | HP G60-120US Laptop
"Can't return from standby mode" the VGA,
Did you un-installed the previous graphic driver? Quick remody:
keep pressed the power button of the cpu and press again to start the computer.
If the system freezes in the stand by mode again;
Uninstall all drivers and re-install it gain. this might solve the problem.
May 31, 2011 | Computers & Internet
Hello, Hi, I've just got myself a brandnew Dell desktop with windows 7 32 bit on it. Everything seemed to work fine, but my computer enters Power saving mode at completely random times while im actually...
The simplest thing to do, as it is a desktop computer, is go to the control panel, power options and set everything to never so the computer never goes into standby mode.
If this does not prevent the machine going into standby mode then we need to perform further troubleshooting.
Jan 29, 2011 | Computers & Internet
The motherboard is an A785GM-AD3 Black. I just built this system and I can't get a display or post out of it. I noticed that a red standby light is solid the entire time power is to it. Please help me. I...
1. Check power cables (It goes standby mode when there is not enough power supply)
2. Check CPU seating and CPU Power socket
in some cases CPU socket(on the MB) may be damaged
3. check the RAM (if one of the RAM malfunctioning)
4. Clear the CMOS/BIOS battery (b4 disconnect main Power supply)
5. CPU Power FAN / Heatsink. If not proper, 4sec system go standby down.
6. Do u correctly connected 12vATX to CPU
I hope This will solve your problem. If not may be need to replace your board.
Sep 17, 2010 | EliteGroup ECS A785GMAD3(V10) Socket AM3...
I am having problem in starting up my system.once system has shutdown ,it fails to start immediately after pressing the start button.even after 2-3 hrs it does not start on pressing the start button.but...
Sir,
Let me tell you that do not use UPS current on to the computer as the current in UPS is (AC) it would blow whole of the power supply or might effect to your Computer processor. As now you are suggested to get new power supply. hope fully this would work
Aug 30, 2009 | Computers & Internet
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
How to turn off Compaq R1500 UPS System?
Press and HOLD the power button on/off..until the unit goes into the standby mode...unfortunately there is not a switch on the back of the unit so you are required to literally unplug the unit...which will completely power down the unit.
Dec 30, 2008 | Compaq R1500 ( 295459-001 ) UPS...
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
I have a Gateway FPD2275W monitor. When I turn on the computer the monitor flashes on for about 2 sec. and then seems to go into standby mode. Even the menu screens will not show up when this happens. When...
Your power supply may not be supplying the required electricity to keep your monitor on. Try plugging your monitor in a different electricity source. Your CPU may be drawing much power from the source and not enough is supplied to the monitor. You may plug the monitor directly to the UPS (uninterrupted power supply) if the cable end allows it.
Aug 31, 2008 | Computers & Internet
XFX NVIDIA GeForce 8600 Graphics Card Logo
118 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
