Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
Posted on Jun 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello can you please help us our printer "brother dcp 165c" it suddely saying " ! Closed Ink Cover " we tryied to reput the cartilage but it still says Close Ink Cover @_@ can you please help us !!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
622
Points
Hp 2420dn printer showed 50.6 fuser error how to solve this problem
Anonymous
Level 2:
Champion:
  • Expert 220 Answers
Anonymous
Expert
Level 2:
Champion:
Answers
220
Questions
Helped
106695
Points
347
Controller pcb maybe faulty.
My printer is dcp-165c... and have continuous ink ..there is an error that says please close ink cover....what will i do????
Remove the ink cartridge and replace. Make sure it is seated correctly. Make sure the ink cover can close all the way. Restart the printer.
" please close ink cover"
The cover for the Ink cartirdges has a switch on it. Try opening the cover, then close it again, the switch may be jammed. Try repeating several times if it does not do anything. If it is still the same case, then someting from the inside of the printer has caused the failure.
8helpful
3answers
28helpful
4answers
My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
4helpful
My brother dcp 165c wont print in black
Hello, please make sure that your cartdridg is well installed and that you took off all protections on it. Unplug your printer from the ac dc and replug it...
Norman Weimar
Norman Weimar
k24674
