Question about Kenmore 98702 Stacked Washer/Dryer
Noise during the spin cycle, the unit sounds like a jet engine causing a very loud noise. we have to turn the volume up to level 70 on the tv in the livingroom
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
duby1990
  • 367 Answers
SOURCE: Washer makes very loud noise during the spin cycle.
Sounds like you have bad bearings. If you use powder soap thats the problem. Powder soap doesnt dissolve all the way and gets into the bearings and eats them away. you will most likely have to have a service technician come out to replace them(Its not just bearings they sell you more than you need and you have to take everything apart... big job). After that use liquid soap.
Posted on Nov 18, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 14, 2008
MNfisherman
  • 11896 Answers
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Posted on Jan 28, 2009
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
Frigidare Gltf1040as0
Good Afternoon Carrie,
I understand that you are hearing a loud noise in the spin cycle as well as water leaking from your Frigidaire washer, model# GLTF1040AS0.
You will commonly hear a high pitched "jet engine" noise during the spin cycle. If you are hearing a vibrating noise, it could be your washer is not resting firmly on the floor. With this you will adjust the leveling legs so the washer is level. If after leveling your washer you are still receiving a vibrating sound, you might want to redistribute the wash load inside your appliance.
If after you redistribute the wash load, you are still hearing a loud noise in the spin cycle, I suggest contacting a local authorized technician.
For the leak I recommend contacting a technician. This way they are able to find where the leak might be coming from and repair it before there is any damage done to your appliance. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire Washing Machines
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Make a really loud noise during the spin cycle
I would check the wash tub. Remove any clothes and examine how the tub sits in the opening. If it is sagging it could mean that the support arms are broken.
Try turning it by hand. It should turn smoothly without any noise. When the washer is in the spin cycle does it sound like a jet engine? If it does, it probally needs new bearings. It can be expensive to fix. Get a few estimates. Hope this helps you.
Jan 07, 2011 | Samsung WF218AN Front Load Washer
Have a unit that started making noise comparing to a loose coin in the tub during the spin cycle and has now turned into a loud binding type noise, doesn't seem to spin as fast either. Any idea what...
The main center bearing is going bad that's why it is not wanting to spin as fast and is also making the loud noise when its spinning i.e. sounding like a jet engine firing up or metal grinding noise. I would not repair this very expensive cost around $300 to $600 to fix I would go buy a good quality used one or a new one sorry for the bad news but that's what it is I see 2 of these a week in my shop same problem but hope this helps.
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
I have a maytag neptune washer and the spin cycle is really loud is that normal. Kinda like a jet engine but it is complete level we checked?
you have described the noise from a front load washer in the spin cycle to a "T", it definately does sound like a jet engine. if it ain't broke...don't fix it!!
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
the machine needs to be opened.its the motor problem.the motor has to be replaced. you can get the motor at  www.repairclinic.com
May 06, 2009 | Amana Washing Machines
Loud noise during spin cycle.
If it sounds like a jet engine and gets louder the faster it spins you have bad bearings and that wont hurt anything. If your using pwder soap that is what made the bearings go out so switch to liquid and it shouldnt get much worse.
Nov 17, 2008 | Washing Machines
Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
May 20, 2008 | Amana NAV2335A Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
19 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
