Question about KitchenAid KGST307 Gas Kitchen Range
KitcenAid gas oven displays "control locked". How to fix?
The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
Kitcenaid microwave light will not dim
We see and repair this a lot. The problem is on the controller assembly.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Since the circuit boards are no longer available, repair is the only option. Details are here.
Dec 02, 2013 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
    To lock/unlock the controls: Turn all surface burners off.
    Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
    To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
    Feb 11, 2011 | Whirlpool Ovens
    (2000 kenmore gas) oven door flashes (locked) model 790.7522991
    I had posted how I fixed it. I had to turn the oven light switch between the door and the oven and wiggle it. It must be defective as It made a clicking sound then my oven unlocked.
    Apr 05, 2009 | Kenmore Ovens
    My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
    Control panel and oven door lock
    The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
    To lock the control panel and both oven doors:
    1. Press and release Cancel.
    2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
    To unlock the control panel and both oven doors:
    1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
    Dec 22, 2008 | Jenn-Air Electric Double Oven
    Maytag clock
    my screen shows locked on my oven and the oven door won't open
    Nov 03, 2008 | Maytag MGR5751AD Gas Kitchen Range
    Need to unlock the controls of my Whirlpool gas oven
    To Lock Or Unlock Cooktop
    1. Turn all control knobs to OFF.
    2. Press and hold the Cooktop Lockout icon keypad for 3 seconds. A single tone will
    sound, and “Loc On” and a cooktop icon will appear on the display. After 3 sec-
    onds the clock display will reappear.
    3. Repeat steps 1 and 2 to unlock cooktop. “Loc OFF” will appear on the display for
    3 seconds, and the cooktop icon will disappear from the display.
    Feb 13, 2008 | Whirlpool SF367 Gas Kitchen Range
    Lighting the oven
    Control Lockout (on some models)
    Your control will allow you to lock out the
    touch pads so they cannot be activated when
    touched or cleaning the glass panel.
    To lock the controls:
    Touch the 9 and 0 touch pads at the
    same time for 3 seconds until the
    control beeps twice. The display will
    show LOC continuously and the time
    of day if not blacked out.
    NOTE: All cooking and timing functions will be
    cancelled when locking out the control.
    To unlock the control, touch the
    9 and 0 touch pads at the same time
    for 3 seconds until the control beeps
    twice, and LOC will be removed from
    the display.
    NOTE: Some models have a Control Lockout
    pad. Touch and hold it for 3 seconds to
    lock/unlock.
    Gas/Control Lockout (on some models)
    surface burners, oven burners and control
    panel so they cannot be activated.
    Touch and hold the Gas/Control
    Lockout pad for 3 seconds until the
    display shows LOC ON.
    Gas/Control Lockout pad for 3 seconds
    until the display shows LOC OFF.
    When this feature is on and the touch pads
    are touched, the control will beep and the
    display will show LOC ON.
     The control lockout mode affects all
    controls. No controls will work when this
    feature is activated.
     The adjustment will be retained in memory
    after a power failure.
    Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven beeping f1 and f3
    Here are the error codes for your range:
    F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
    2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
    2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
    Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
    Nov 22, 2007 | Kitchen Ranges
    KitchenAid KGST307 Gas Kitchen Range Logo
    29 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Dan Webster
    Dan Webster
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
