Question about Pelouze Office Equipment & Supplies
Replace backup battery
How do I replace the battery on a PE10 Scale?
How do I clear the 'L' error on my bathroom Salter scale. I have changed the battery but I cannot get the error to clear.
new batteries? or one's that have been sitting around.
they may be low.
what they say to do...
1.
Open the battery compartment on the scale underside.
2.
Remove isolating tab from beneath the battery (if fitted) or insert batteries OBSERVING the polarity signs (+ and -) inside the battery compartment.
3.Close the battery compartment.
4. Select kg, st or lb weight mode by the switch on the
underside of the scale.
5.For use on carpet attach enclosed carpet feet.
6.Position scale on a firm flat surface. next......
INITIALISING YOUR SCALE
1. Press the platform centre and remove your foot.
2.'0.0' will be displayed.
3.The scale will switch off and is now ready for use.
This initialisation process MUST be repeated if the scale is moved. ie battery replacement.
Feb 14, 2018 | Salter Health & Beauty
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
Jun 04, 2014 | Conair WW60 Weightwatchers Scale
Replacement battery for 5786 taylor scale
Fixya does not sell replacement batteries.
Dec 23, 2012 | Taylor Health & Beauty
Can i replace the battery in my Royal EX2 Exacta Scales Postal scale?
90 day warranty on this scale to begin with so when battery dies after 10 years, you have no warranty to preserve. Royal EX2 Exacta Scale - royalsupplies.com - manual downloadable.
You will need a Phillips #1 and I think a #0 for best fit. 2032 lithium coin battery (fresh, so it will last another 10 years). 1) Peel off large label from bottom (Xacto knife to get under a corner). 2) Remove 3 screws attaching pan to mechanism. Use magnitized P0 screwdriver here. 3) Remove 4 rubber feet, and four P1 screws under them. 4) Opposite side of display from the button is the black battery case. Use P0 screwdriver to remove three screws. Replace battery. 5) Put back together...
Don't mess with the mechanism inside (at least not if you want a calibrated scale) any more than you have to while changing the battery.
Jul 04, 2012 | Health & Beauty
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
When you step on the scale the readout says "LO". Does this mean low battery, and if so I can't find a battery to replace.
Yes it means battery needs replacing. Check oringinal papers that came with scale to see if you need to order special battery. Otherwise go to a battery store that recharges batterys. They usually carry most makes. Take your battery with you so you can match right one.
Dec 10, 2009 | Taylor & Digital Scale Lithium Scale
78 people viewed this question
Top Pelouze Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Pelouze Office Equipment and Supply Expert? Answer questions, earn points and help others
