Question about LaCie (300770) 250 GB Hard Drive
My 500GB Lacie harddrive says it full too
It says there only 18MB of free space left, but there's no way this is right.
when i delete some information of the drive, more free space comes available.. but i don't get it, if i add all the stuff thats on harddrive, i only come to around 150GB.
  • kevincondera Jun 19, 2009
    well, i fixed it myself, got out my east-tec eraser program, wiped the free space clean, solved the problem
    solved the problem with east-tec eraser, just wiped the free space clean, fixed it, thx
  • 3 Answers
Way too little information to solve this problem. Operating system and connection type are good places to start. errors if any during installation, startup, or during connection also would help. format type and OS format type and if it was previously used on a different type of system like mac to pc or linux/unix.
Posted on Jun 19, 2009
Why does my new 500gb lacie setup say 375.7 MB, Zero free?
Hi Anon
I think this is the setup disk, your 500gb disk will have have hundreds of gigabytes of free space, remember that 375.7 MB is roughly a third of 1 gigabyte.
Aug 31, 2014 | LaCie Rugged Triple hard drive - 500 GB -...
Free Local Disk
If you are trying to free up space then get CCLeaner. It will delete a ton of junk files with the click of a button and it's FREE.
http://majorgeeks.com/CCleaner_Standard_d5125.html
Jun 25, 2012 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
ONLY 650 MB OUT OF ONE TERABYTE lacie all terrain
For anyone else that runs into this issue, you don't need the EXE.
Follow the instructions on here to get to the Storage control panel area on your computer so you can view partitions:
http://www.ehow.com/how_5022760_check-partitions-hard-drive.html
Locate your LaCie drive, and delete the small partition that shows as "Healthy". Once you delete that, you should have a large "Unallocated" space. Format that normally using either FAT32 or NTFS. Your drive will now have its full allocation (which with a 500GB drive, should be around 465GB, give or take depending on the system accessing it).
Mar 31, 2012 | LaCie Rugged All-Terrain (301017) Hard...
I bought today a lacie hard disk 500GB and instead of 500GB has only 9.99 MB space.What's the problem?
Sounds like your have a 9.99mb partition on your drive with the rest being free space.
If you are running windows goto the Computer Management program and check under storage> disk management to see if your 500gb drive is there. if it is delete the existing partitions and reformat the entire disk to NTFS
May 21, 2011 | LaCie Big Disk 500 GB Hard Drive
My lacie hard drive turnes on ,shows that its running,stops running and keeps showing pink light but does not show appearance on my laptop,
Right click "My Computer" and select Manage. In the window, select Disk Management on the left column. If the drive is not listed on the right column, then the BIOS has not detected the harddrive - it might have a harddrive password lock. You will need to go into the BIOS and unlock it with the password.
Nov 01, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
LaCie (300770) 250 GB Hard Drive Logo
179 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
