Question about Frigidaire ATF6000ES Front Load Washer
Screw on the drum loosens and he belt falls off and u can hear the motor going but the drum doesn't spin
Washing machiine washes then falls off in the spin cycle...but u can still hear the motor going but the drum doesn't ,spin....plus the screw in the back of the drum loosens
  • Frigidaire Master
  • 5,323 Answers
READJUST TENSION ON THE BELT AND CHECK WHERE IT ADJUST FOR LOOSNESS
Posted on Mar 31, 2015
  • 298 Answers
SOURCE: putting a belt back on. On a front load Washing Machine
There should be a adjustment to tighten the
belt a bracket similar to bracket to tighten
a belt on a automobile alternator you will
probably need a open end or combination
wrench or you might be able to get it with a
socket wrench
if you can get the belt over one pulley
and over the top of the other pulley and
then turn the pully towards you it may
pop on with the help of a large screwdriver
make sure it unplugged
Posted on Nov 17, 2007
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
onthejob5130
  • 640 Answers
SOURCE: Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Posted on Feb 02, 2009
  • 98 Answers
SOURCE: Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Apr 01, 2009
  • 3741 Answers
SOURCE: Washer will not spin for
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jul 11, 2009
Samsung front load washer doesn't go...no codes...just hear the motor trying to run?
Hi,just food for thought,if you can hear the motor runing it could be that the belt has come off,it the belt attaches to the motor to the drum,so if its come off the motor will spin and the drum wont,there should be a entree on the back of the machine with some screws undo them and and you will see the back of the where the belt is.
good luck.
Mar 05, 2016 | Samsung Washing Machines
Zanussi Essential 1400 ZWF14070W1
Check the belt that spins the drum for proper tension. If it has stretched you will have a hassle. Often you can loosen a belt pulley and put some extra tension on belt, restore friction and operation till belt is replaced with a nice, new tight one.
Nov 23, 2013 | Washing Machines
Hotpoint WF100 doesn't spin
its a stretch fit belt ,give it some application and it will fit
Dec 01, 2012 | Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Candy grand o not spinning when loaded
Kindly replace the motor to solve your problem
May 17, 2010 | Washing Machines
Wont spin even though you hear motor and drum is freely movable in both directions
My guess, if you can hear the motor spin, is a broken drum belt. Take the top off with two screws in the back and you should see the drive belt on the top of the drum. If not, you have the answer! Good luck!
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer drum not spinning
yes you will most likely need a belt.
Mar 11, 2009 | Kenmore Washing Machines
Hoover Premier 10.1 kg washing machine
do you actually see the motor spinning? or think you hear it, check the belt hasn't come off, or gone slack, it needs to be fairly tight but not too tight, if the belt and pulley go round but the drum doesn't then you have serious damage and need a new inner drum hope i have helped and if i can help more get back to me, i am an appliance engineer of 20 years
Oct 05, 2007 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
