Question about Marantz SR5500 Receiver
Problem with Marantz SR5500 Receiver
I have a Marantz SR5500 Receiver purchased about 18 months back. Usage is the receiver is low. However, since one month started having problems with the Receiver. When Switched ON, the receiver plays for sometime and then flashed "Protect" and goes into a Standby mode. Will not be able to use the Receiver once this happens.
Re: Problem with Marantz SR5500 Receiver
Had the same problem. Tried different power leads, checked earthing but power plug does not have earth connection to chassis.
The power socket was the problem. There had been too much heat applied to the internal power connections causing the prongs in the socket to retract slightly. Noted the power lead plug did not engage tightly with the socket.
Replaced the socket taking care not to overheat the connections. All fixed.
Might be a bit late for most of thoise who have dumped a great amp.
Hope this helps.
Posted on Apr 11, 2009
I have the same problem, and it is not for the surge.
Posted on Oct 09, 2008
  • 143 Answers
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Posted on Nov 03, 2007
0 characters
3 Points
My antenna jack on a marantz sr5500 broke. how do i replace it and where can i find one
If you still have the connector and if your Tuners board is not broken, you can solder it back on if you are careful. If not replace the whole tuner.
Part# 90M-AV000350R
Jun 21, 2012 | Marantz SR5500 Receiver
Cant play ps3 digital audio through Marantz SR5500
Check to see if there are any software or firmware upgrades for your receiver and you PS3. This could be a handshaking issue that is easily corrected with an up grade.
May 02, 2012 | Marantz Audio & Video Receivers
Center channel dosen't work on 10 yr old marantz 500$ receiver. Should I just buy a new one?
I'd do some more investigation first. Have you determined if the amplifier for the channel works or if it's a preamp problem using the built-in speaker setup controls?
With this unit's great audio processing features you might be able to bypass a failed amplifier using the pre-outs and drive an external amp for the missing channel.
You could always just get a modest stereo amp (like a Carver M-100T and bridge it), or use the extra channel for another center speaker or a subwoofer, for example.
Aug 12, 2010 | Marantz SR5500 Receiver
Marantz sr5001 has pcm light flashing after child pushed buttons on front of receiver. no longer getting audio/video in tv mode but other modes are still working without issue. how can I get audio/video...
I suppose pcm light means that the pcm mode is turned on (pcm meaning pulse code modulation), in other words, the unit was switched to digital signal, so if the digital rca or optical TV input on your reciever is not connected to anything, then you're not getting any signal into the reciever in digital mode. You probably just need to switch the unit back to analog mode (see if there is a button that says something like digital/analog, pcm/analog, optical/coax or similar, try pressing it, see if there is any change).
I might just be totally wrong on this, however, probably the best way to learn what happened is to read the user manual if you do have it (see what the pcm light signals for and check any chapters inside the manual related to that topic).
good luck
3rq8 (Triarcuate)
Jul 25, 2009 | Marantz SR5500 Receiver
I have a Marantz SR5500 and the unit will not stay powered on.
I have this problem. it is caused by an o/c mains transformer primary winding. the clicking and flashing light is the stanbyy circuit trying to switch the power on to the main (large) transformer when it gets no voltage out it switches back off
May 19, 2009 | Marantz SR5500 Receiver
Marantz SR5500 Owners Manual ?
An English version is available from the Marantz USA website as a PDF download.
Open the following link:
Then click on the "SR5500 User Manual" link listed under the "Manuals and Documents" heading
Dec 21, 2008 | Marantz SR5500 Receiver
Marantz model 5500 AV Surround Receiver
Hi, hope this helps, try (1-800-remotes), these guys have a wide selection.
Oct 22, 2008 | Marantz SR5500 Receiver
No audio
Go to amp set up menu and make sure it knows the cables you are useing,ie-if the dvd is wired with coax for sound go to input set up and tell the amp you are useing this type of cable.If this is not the problem and the sound is going off one device at a time your amp needs to go back to your dealer.
hope this helps.
Jul 12, 2008 | Marantz SR-5600 Receiver
Marantz SR5500 Receiver Logo
1,523 people viewed this question
Top Marantz Audio & Video Receivers Experts
Pieter Vleeshouwers
Are you a Marantz Audio and Video Receiver Expert? Answer questions, earn points and help others
