Question about Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
When power button is pushed vostro 1000 nothing happens
I have a Dell Vostro 1000 that my kids dumped a full cup of water on.
That would be my best guess. Even with a partially bad CPU, memory or HDD you should at least get to the BIOS screen.
Apr 21, 2013 | Dell Vostro 1000 Notebook
Dell vostro 1000 power button press on..but lap is not working
unplug the power chord, take the battery out for 30 seconds. plug them both back in, restart.
Let me know.
tony
Feb 09, 2013 | Dell Vostro 1000 Notebook
I put my Dell Vostro 1000 laptop on charge and click the power button for it to turn on and nothing happens. When I put the AC adapter on charge the batter LED flashes on and then off. Please may you help...
Hi there its sound like SMPS ( power supply Unit ) problem. Some how he not able to accept the power or hold the power and then forward it. It Is complete hardware problem.
Jan 17, 2011 | Dell Vostro 1000 Laptop
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Dec 07, 2009 | Dell Vostro 1000 Laptop
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Dell Vostro 1000 shut down and won't turn back on
nope, it is your dc power regulator board. you will note this happens if the battery is in or out of the laptop. that is the key test. some regulators are on the main board and some are seperate for this reason. I think the vostro though is on the main board. A little board re-work will resolve this issue after replacing some components, but this is way beyond a home user's ability.. trust me on this. Sorry for the bad news. Thanks!
mrstan
Aug 29, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Dell Vostro 1000 will not boot.
It maybe the power adaptor is loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Aug 26, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Won't Start No lights flashing does nothing when I hit the power button
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
May 08, 2009 | Dell Vostro 1500 Notebook
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2 Logo
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
