Question about IBM ThinkPad T30 2366 Notebook
Upgrade hard drive from 40GB to 160 or 320?
I'm about to have the 40GB hard drive in my IBM T30 2366 ThinkPad swapped out with a much higher GB drive. My plan was to replace it with a 320GB hard drive but I was told the 160GB is as high as that computer can take, that any higher will actually slow down the computer. Is this true? Is it a job i can do myself?
  • 1,170 Answers
A computer can handle any amount of Hard disk. The speed and performance of the computer depends upon the way you use it. It is possible to replace the harddisk by youself. Here is a guide : http://www.fonerbooks.com/laptop_1.htm
Posted on Jun 19, 2009
Are all hard drives the same in size? I mean can I take a hard drive 36 GB and put it in a IBM Lenovo ThinkPad X41?
Laptops hard drives have the same physical size but they maybe use IDE/PATA or SATA data connections.
This WEB site has the specs of this model Thinkpad.
www.notebookreview.com/default.asp?newsID=2362
Dec 29, 2012 | IBM Lenovo ThinkPad X41 Motherboard...
I have a IBM thinkpad t30 the on/off button every time I try to turn the laptop on it takes a long time for the computer to come on. Whats wrong ?
This is in laptop terms an older laptop. i recall it was fitted with a 20 or 40GB hard drive and with 256mb of ram and unless you have since upgraded it, it is possible the hard drive is filling up or it is beginning to fail through age.
Things you can try:
  • See how much space is availible on the hard drive, to work effectively there should be at least 2 gb of space that windows can use as a swap file
  • In My computer / C drive/ properties/ tools, defragment the hard drive and then run a disc cleanup, see how much space is fred and if it runs faster after the hard drive has been decluttered and defragmented.
  • If you still have problems / the hard drive is filling up, move some files to a seperate location such as an external drive to free up space.
  • If after this, you still get a slow start up, download a copy of HDD Tune (the free version) and do a health check on your hard drive, any bad secorrs or RSC errors means you should consider replacing the drive asap.
  • Finally, consider upgrading the RAM
Jan 22, 2011 | IBM ThinkPad T30 2366 Notebook
What size of hdd is supported by this laptop?
This is part of the A31 specification.
Hard drive features
  • A31 standard 2.5 inch 30GB
  • A31 standard 2.5 inch 40GB
  • A31p standard 2.5 inch 60GB
  • Supports two additional hard drives which can be used concurrently to offer expanded storage
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 5400 rpm
  • Although you can upgrade the hard drive, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 hard drive adapter is designed to provide this flexibility with a second hard drive in the Ultrabay 2000
Dec 06, 2010 | IBM ThinkPad A31 Notebook
Wat is the maximum hard space that a IBM thinkpad t22 can have
> maximum
The maximum is 500 GB (for the older-generation of IDE-interface disk-drives), since nobody makes IDE drives larger than 500 GB, or 2000 GB for the new generation of SATA disk-drives.
Sep 21, 2010 | IBM ThinkPad T22 2647 Notebook
Upgrade from 40GB to 250GB WHATS NEEDED?
I usually use a USB to IDE adaptor and software such as clonezilla
I hook up the new drive to the adaptor and then run clonezilla to duplicate the drive. If you are more experienced with other clone software such as norton ghost then use what you know best
Clone the drive and then just swap them out.
OR you could get one of those 2.5" external drive cases and use that to do the exact same thing so that when you swap the drive out you end up with a nice 40Gb external one too
prices for either the case or USB adaptor are very cheap and they are both useful to have around.
Hope that points you in the right direction
Bob.
Jul 22, 2010 | Compaq (201066-B21) 40 GB Hard Drive
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
I'd like to upgrade the HD of my Thinkpad 570 2644-1AG from 4GB to 10MB or even more. IBM system FRU parts list only shows 6,10 and 12 GB as compatible drives. I have found a 40GB Toshiba IDE drive ,...
It most likely will work, but the BIOS (might be too old) may not allow you to access the full capacity of the hard disk.
You would normally lose approx. 10% of the capacity when you format the hard disk.
Apr 15, 2009 | IBM ThinkPad 570 Notebook
Problem with audio in ibm thinkpad t30,2366-y1b model
T30- no sound altho SOUND MAX drivers installed...
Try Control Panel, Sounds, Sounds (tab), choose a sound toward bottom of list. press the BLACK PLAY ARROW...if BLACK SQUARE appears at the arrow, your sound is installed $\& probably OK...
NOW,,,insert a musiv CD. then press the VOLUME BUTTON, (2nd one over from the THINKPAD button, & you should get sound aplenty !!
Dec 13, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T20 Type 2647
I currently own 3 Thinkpad T-20 Laptops. They all have a 700 mhz processor in them, and so will yours, more than enough to run windows xp, in fact, I am running Windows XP Profession on one of them. The PC100 is the type of memory it uses, not the processor speed. i recently installed a 120 gb drive in one of them so you will have no problem installing a 20 or 40 gb drive, or larger.
Dec 08, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T30 2366 Notebook Logo
183 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
