Question about Hozelock Cyprio Prima Xl 1000 Gph Pump
Hozelock tritan 3000 pump
How do i remove the wiring
Hozelock pressure sprayer , when I pump the sprayer the pressure release valve pops up loosing all my pressure
That's what it is designed to do when there is too much pressure, usually sprayers don't get used that much to ware out that part. You might be having trouble getting spray out the wand, in that situation it is probably clogged. You have to remove tip and see if you can clean out a little particle blocking it. I know it is easy to occur and it happens if some dirt falls into the tank while filling. Hope that helps.
Jun 09, 2016 | Hozelock Garden
Hozelok Titan 2000 pump not pumping. Electricity is getting through, pump making a funny noise but not pumping.
You have to prime the pump first. Turn off the pump, remove the priming cap, fill with water, close, then run it. Repeat as needed to get water pumping.
Sep 11, 2013 | Hozelock Garden
I have a Hozelock garden spray oscillator that no longer oscillates. I have tried to dismantle it but am unable to easily open the internal mechanism to see what's preventing the oscillations. Do you...
Hi Simon from Hozelock, if its within warrenty, please call us for a replacement, or email us at info@hozelock.com but before you do, try cleaning the inlet filter (behind the inlet - which needs removing).
Jun 30, 2011 | Vacuums
Need instructions on how to install hozelock cyprio filter & pump
need instructions on how to set up filter, hazelock cyprio please
May 21, 2011 | Hozelock Cyprio Prima Xl 3400 Gph Pump
I have an lg tritan and I don't like how my phone vibrates. Is there any way I can change the vibration pattern on my phone?
The vibrate is set by the phone and don't believe they changed But if the can is b in the hidden menu LG Tritan Information Menu a. From the phone dial pad dial b. #help*help (#4357*4357) LG Tritan Feature Menu a. From the phone dial pad dial b. ##Feature (##3328873) LG Tritan Service Menu a. From the phone dial pad dial b. ##LGSERVICEMENU (##5473784236368) c. Service code  000000 LG Tritan Programming Menu a. From the phone dial pad dial b. ##PROGRAM840 (##7764726840) c. Service code  000000
Jan 16, 2011 | LG Cell Phones
I have a hozelock bioforce filter that i have
Sounds like the the bypass valve may have been disturbed and so water is coming out of the air bleed hole.
I suggest you turn off the pump, remove the bypass valve cover (clear part that quater turns off bayonet style), extract the red valve (careful not to lose spring), rub some pertoleum jelly (vaseline) around the seal of the red valve, replace spring, red valve, press the red valve a few times to ensure it returns, replace clear cover and turn pump back on.
This should ensure the valve is working.
May 23, 2010 | Hozelock Garden
The cable to my Hozelock Titan 5500 has been cut
Follow the cable to the pump there should be a plate on the pump take the 2 or might be 4 screws out remove plate and you will see three wires a black a green and white the black is power the green is ground and the white is common there should be small screws holding each wire in to place remove screw take each wire off make sure you mark them black green white were they came off most cable you cand get at Home depot or any Hardwhare store take cable with you so you get the same wire gauge you took off. Most are a 110.
Apr 17, 2010 | Garden
How do i take apart and fix my Hozelock Titan 1450 pump''
http://www.hozelock.com/uploads/pdf/spares%20manuals/2008%20AQUATICS.pdf
Apr 04, 2009 | Garden
Hozelock Cyprio Prima Xl 1000 Gph Pump Logo
Top Hozelock Garden Experts
richie46
J Walsh
Level 1 Expert
Bill Boyd
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
