Question about Axial Ax90015 EXO Terra Buggy, 4wd
Whizzing sound from axial exo terra buggy
What is the solution
Euphorbia Trigona cactus turning yellow why
did you move it to a brighter spot in your home. reading about this plant I would not have one anyplace near people quite hazardous
Feb 26, 2015 | Hagen Exo Terra Jade Cactus Terrarium...
Watersoftener salt tank keeps flooding
Sounds as if the head has a valve sticking, Need an overhaul kit that has new paddle valves with screen and injector also. Unplug unit, put into by-pass (3 valves above it) then manually rotate cam to depressurize head and tank, follow kit instructions to overhaul, or you may want to call a plumber.
Jan 02, 2014 | Water Reservoir
Front drive shaft turns but front axial wont roate
Unfortunately, It sounds to be an internal planetary gear problem, which will probably require rebuilding or outright replacing
Feb 27, 2013 | 1992 Ford Explorer
Dont have money need food pellets for my bearded dragon for free
You do have other options besides pellets. http://www.anapsid.org/bearded.html is a great source of information. My beardie eats crickets and fresh fruit and veggies (make sure fruits and veggies are listed as "safe" and chopped or cut into appropriate sized pieces. For mine, I shred the fruits and veggies in a food processor so that he can not be picky and just eat one or 2 of the different foods. If you use wild caught insects or use plants from your outside around your home, make sure you are not getting poisonous insects and/or plants and the they have not been exposed to pesticides, weed killers, some types of fertilizers, or any other harmful chemicals.
Aug 14, 2012 | Exo Terra Juvenile Bearded Dragon Pellet...
Cannot set combination
I recommend that you post your question under the correct category (home and garden maybe?). If you add more details to it, it might be easier for Experts to understand the question and answer it.
Jul 20, 2012 | Hagen Exo-Terra Terrarium Lock
How to troubleshoot this fogger
I would take it back to the place that you bought it or contact the manufacturer and tell them that it's not working properly.
But first i would make sure all the parts are secured in and the batteries are working properly.
Jun 18, 2012 | Hagen Exo Terra Mini Fogger
Axial Ax90015 EXO Terra Buggy, 4wd Logo
377 people viewed this question
Top Axial Reptile Experts
windryder
Level 1 Expert
john h
Are you an Axial Reptile Expert? Answer questions, earn points and help others
