Question about Turbo Power Twin Turbo 2600 Hair Dryer
Stopped Working I was using my hair dryer and it suddenly stopped working, what can I do to fix it?
Conair hair dryer 1002axa stopped working
The thermal cut-out on hair dryers is usually self-resetting, the device will restore power once the unit cools down... Most of these types of problems are due to lint clogging the air intake and causing overheating, be sure to clean the intake before attempting a repair.
May 23, 2016 | Dryers
Wet i Pad
hi Laurel,
remove the covers.
Disconnect the battery.
Let it dry with low or mid sunlight, or use hair dryer for that.
then reassemble and take care with lcd and all flex cables and if you cannot handle this please go for expert help.
regards,
nuwan.
Jan 10, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
Ice maker all of a sudden stopped working.
Remove the ice bucket and look for ice hung in the fingers. Use a hair dryer to melt a jammed ice cube. Keep at it till the fingers move free and advance to the next harvest cycle. If the ice mold is empty replace the water valve. If the ice mold is full replace the ice maker.
Aug 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
Maytag refrigerator model #MFD2561HEW - Water dispenses from side wall. SUDDENLY STOPPED WORKING. Have replaced water filter. STILL NOT WORKING. Any suggestions?????
Hello, Thank You for using FixYa. I will be helping you today. Your water tank is frozen! Itson the back wall of the fresh food section if you look behind the drawers you will see it. Use a hair dryer and heat it untill you get water out of the dispenser. This is a common issue with this model.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Maytag Refrigerators
I plugged a hair dryer in my room then it wouldn't come on in both rooms but all the other rooms outlets work this is the second time this month this problem has occured
Please check the circuit breaker fuses. The one in your bedroom is of lower amps. If it is 5 amps replace it with 15 amps. Also check the connections of the socket. It could be that wires there are not connected with the socket or they are burnt out thus no connection.
Dec 20, 2010 | Electrical Supplies
Dryer suddenly stopped working completely
FUSE!! LOCATED ON THE BACK OF THE DRYER IS WHITE AND OBLONG SHAPED
Apr 27, 2009 | Dryers
Dryer suddenly stopped working while in use!
Try your thermal fuse. It is on the left side of your element. It has 2 white wires. I just replaced mine for the exact same problem. Also, make sure your dryer isn't full of lint.
Mar 21, 2009 | Crosley CDE6000 Electric Dryer
Indesit Washer/ Dryer 1200
A lot of times when people move they find their dryer has suddenly stopped working. Check the voltage at the outlet, make sure it matches the voltage on the i.d. plate on the appliance. I know people who didn't want to fuss with it and bought a new dryer only to find it did the same thing.
Mar 15, 2008 | Dryers
Turbo Power Twin Turbo 2600 Hair Dryer Logo
21 people viewed this question
Top Turbo Power Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Turbo Power Health and Beauty Expert? Answer questions, earn points and help others
