Carver problems red light flashing
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
If you have a red flashing indicator, your amp has DC Offset, meaning a damaged amplifier.
If you are interested in having your Carver repaired, please look to my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Aug 04, 2015
I have a constant blinking ted light on my carver av405 amp can't get any sound out of it
The amplifier is in "protect" mode, possibly because the output stage was driven too hard or it overheated (thermal shutdown).
Nov 13, 2016 | Carver Audio Players & Recorders
My carver HR - 895 was staticy at times on FM and all the sudden shut off. Now it won't Power up at all what do I do ?
Do you have an indicator light blinking or illuminated? If so, your amp has DC Offset, meaning a damaged amplifier. The static noise you heard, may have been DC voltage on the speaker output.
If you are interested in having your Carver repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Feb 10, 2015 | Carver Audio Players & Recorders
Problems hooking up carver17 to equalizer
Take the input jacks out of the carver, plug in into the EQ inputs, then plug another cable into the EQ out then plug those cables into the carver inputs. You good to go.
Dec 21, 2013 | Carver Audio Players & Recorders
I don't have any instructions so i don't know how to hook up my speakers and the t.v for surround sound i have a carver avr 100
You should be able to online to the manufacturer of your products and download manuals. However, I will try to help.
Connect the sound output cables from your DVD player including, left/right(white/red) as well as the Coax output/input if your DVD and your Carver each have this feature for enhanced sound on certain DVDs, and connect to the matching DVD inputs on your Carver.
Then, connect your DVD video output either by use of your RGB(RED/GREEN/BLUE cables or an S Video cable to your the matching video inputs on your t.v.
On the back of your Carver, you will find outputs for left and right speakers, connect to the left and right speakers with proper wire. Make sure that the 2 conductor wire is connected with the same side(polarity) on all speakers for the best sound quality.
You will also find rear channel left and right outputs on your amp, connect those to your rear right and left speakers.
Connect the center channel speaker to the center channel speaker output on your amp.
If your Amp has a sub-woofer output and you have a subwoofer, make the connections on that as well.
Test all of the speakers with a feature that many amps have on the menu using your remote, simply called test. if all speakers are connected correctly you will be able to hear each one as they are individually tested by the amp. Hope this helps out.
Oct 05, 2009 | Audio Players & Recorders
I have a carver M 1.5 amp rt. channel is out.
Carver designs in general are not easy to repair. I would recommend that you send this unit into a Carver authorized service center. The likely problem is the output transistors, but the driver circuits and predrivers are not simple designs and if there is a problem there, it could effect the outputs. Tracing this will require equipment and schematics that I don't believe are available on the net.
Dan
Sep 04, 2009 | Carver PM950 Amplifier
Carver cascade 2 burning smell
CASCADE 2 WATER HEATER WATER ISNT GETTING VERY HOT...HELP
Apr 02, 2009 | Heating & Cooling
Carver C11 preamp problem
I found out through the Carver Audio forums that metal shavings inside the case are an issue with this unit. So I used an achohol based spray and cleaned the switchs and the circuit board, (there was a fair amount of shavings found). It has been running for 14 hours with no problems.
Aug 02, 2008 | Audio Players & Recorders
Carver tfm-35x power amp light replacement
I just picked up the same amp, a Carver TFM-35x, with the same problem, the bulbs that light up the meters are burnt out. They aren't hard to replace, but I didn't know what bulb to use. I found out today that you need to use 12 volt, .15 amp bulbs (150 milliamp). And it needs to be an axial-type bulb.
Jun 21, 2008 | Audio Players & Recorders
Carver M-400a schematic
You are not likely to find any Carver stuff for short money. What is the problem you are trying to solve? Maybe you don't need a schematic.
Dan
Jun 11, 2008 | Carver Audio Players & Recorders
90 people viewed this question
 Grubhead
Grubhead
