Question about Kenwood Food Processors
Shock/ leakage current
Feel leakage current / electric shock during running.We observed 2 set having same problem....please advise what to do?? Regards fahimhasnain@yahoo.com
My bowl will not turn by itself anymore on my Oster Regency. How can i fix this problem?
Unplug electricity cord from wall and disassemble bowl carefully. Clean dirts on moving parts. Be careful not to leave any liquid on any piece.
If motor output shaft rusted; use some rust remover on piece of cloth and clean it. Be carefull; don't use too much rust remover and don't let it go into motor to prevent electrical shock. Try to turn output shaft by hand. If it turns easly assemble everything back again. If it doesn't turn that means; motor might has some issues. There is no way to fix it but changing motor with a new exact one.
Nov 19, 2014 | Food Processors
My Oster 3212 food processor will not turn on.
You have to make sure that both the bowl and the cover are locked into place. Sometimes if you wiggle it a bit, it will go into the right spot. Make sure that the outlet you are using works.
May 22, 2014 | Oster 3212SNB Food Processor
Motor will not start
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 10, 2014 | Cuisinart DFP14 Food Processor
Food processor model KFP600WW Spindal spins very slowly !! What's the problem ??
HI.When the problem is related to themovement of one of its parts,the usual problem is in the motor.Have you tried to disassemble parts and try to look at the motor.It is not advisable to keep the motor running while the cover is open however for the purpose of observing what's the motors behavior while the system is running.Can you check the gears of the motor and check if the motors terminal gets the same amount if voltage reqiured.
Jul 21, 2011 | KitchenAid Food Processors
How to load feeder cuisinart dlc7p?
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 03, 2010 | Cuisinart Food Processors
Moulinex Ovatio 3
Hi YOu could order one from Moulinex themselves. I don't know where you are located but check out this link:
http://www.moulinex.co.uk/pages/contact_us.htm?OnpageA=4 Follow the links to the consumer service/product enquiry.
Either that or check EBay - currently there's a whole machine on the UK site bidding only.
Mar 28, 2009 | Moulinex DG6 Food Processor
Food Processors Logo
20 people viewed this question
Top Kenwood Food Processors Experts
tfelton3
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
