Question about Lexmark C544dn Laser Printer
Lexmark c544dn printing garbage pages
Printing multiple pages go garbage characters
SOURCE: Lexmark x1185 printing problems
my lexmark will not print in color
Posted on Jan 30, 2008
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
SOURCE: lexmark 2500
I contacted Lexmark regarding this issue. I was sent back several steps to follow in order to solve this problem. I couldn't find half of what they were talking about. But I opened the control panel, right clicked printers, server properties, and then advanced. Make sure that both boxes are checked. Then the following directions should work. I just printed several copies of a multi paged document with no problem. Yay.
If these don't work or you can't find things they are talking about try the above first and then these. I had to check that box before I could find the tabs and buttons they were talking about.
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and
"Printers."
2. Then, right click on the Lexmark printer icon and left click
"Properties."
3. Either on the "Advanced" tab or the "General" tab for some models,
there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to
"Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
Posted on Apr 15, 2008
SOURCE: Lexmark 2600 not printing
I recently had the same problem. Your Lexmark printer has automatically placed itself on pause. You must go to the control panel and unpause it from there. Its' simple, just go to control panel and select printer and faxes. Select your Lexmark printer and right click it. Then select resume from the drop down menu. Your printer is now unpaused and ready to print!
Posted on Dec 28, 2008
  • 684 Answers
SOURCE: lexmark x4650 AIO, will only print first page of multiple pg doc
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X1100 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Posted on Feb 05, 2009
I have a Lexmark C544dn printer. I am getting a yellow haze on the right side of all pages printed.
Check the transfer belt and clean if necessary with Isopropanol (IPA), and a soft clean cloth. Also check the drum for the same. Handle with extreme care as these are fragile and expensive. If none of those fix the issue you may need to get the laser lenses cleaned professionally.
Sep 09, 2013 | Lexmark C544dn Laser Printer
Is there something like a reset button on my HP 4000 TN? It is printing garbage, and I cancel job, it seems to cancel it, but starts printing garbage again. Tried turning it off, etc.
in the print queue
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel:
hope this helps
Jul 13, 2011 | Computers & Internet
HP Laserjet 1200 prints garbage when printing pdfs
it may be you have a virus in your computer
Mar 25, 2010 | HP LaserJet 1200 Printer
Printing errors
Try printing one page at a time and see what happens. Repost!!
Jun 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
6. Try printing again.
Apr 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
i dont know how to conect lexmark printer X4250 to my computer
Dec 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Will not print
Does this happen when you print from a word document, PDF etc..
What operating system are you using?
if you are using Windows
open your printer folder from the control panel print a test page from the driver.
If you try to print something and strange characters print.
either you have a corrupted print job in the memory..
Clear the Print que from the PC, unplg the printer for a few minutes.
You possibly could have the wrong drivers installed, which will also cause this problem.
this is a link to Lexmark, and you can down load the proper driver here.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:436:0:0
Aug 19, 2008 | Lexmark X2250 All-In-One InkJet Printer
Crazy characters start to print when printing from pdf doc or certain websites
I understand that the printer is printing garbage when you are trying to print from internet.
Please follow the below given instructions to resolve the issue.
This issue can occur if the data send from the application from which you are printing, is using the PC-8 character set. This will produce a smiley face or garbage charters each time an unsupported escape code is sent by application. To know the character set, please contact the manufacturer of the application.
Also, you can follow these steps to disable the power managment in the comoputer.
1. Right-click My Computer, choose properties
2. Click Hardware tab, click Device Manager button.
3. Click the + next to Universal Serial Bus Controller.
4. Right-click USB Root Hub, choose properties.
5. Click Power Management tab.
5. Uncheck the option "Allow the computer to turn off this device
to save power.
6. Click Ok.
If the issue persists, follow the instructions from the below given weblink to resolve the issue.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01105&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue.
Regards,
Lawrence
Nov 13, 2007 | HP Photosmart C6180 All-In-One InkJet...
Lexmark C544dn Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
