Thermostat reciever unit light isl red - Washing Machines
There is a flashing red light below on the left side of my firebox
THAT FLASHING RED LIGHT IS PROBABLY THE RECIEVER FOR YOUR REMOTE CONTROL & EITHER IT'S SIGNALING PROPER OPERATION, OR YOUR BATTERIES AT FIREPLACE RECIEVER ARE LOW, & SOON THE REMOTE WILL NOT OPERATE IT AT ALL. CHECK THE BATTERIES!
Dec 25, 2012 | Heating & Cooling
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Calling code 44 is for what country?
United Kingdom and Isle of Man
Jun 24, 2011 | Computers & Internet
The unit is no longer heating the water. The red light comes on indicating that the unit is heating the water, but only cold water comes out of the faucet. We've tried raising and lowering the...
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
Mar 06, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
My non programmable digital round thermostat just stopped working it wont even light up like its dead
try taking off the wall do not pull any wires wait a few minutes and re-install if this does not reset then you should just buy another...........is the power on to the unit? check the breaker panel also to ensure the unit is recieving power. the thermostat gets its power from the AC unit.
Mar 04, 2011 | Honeywell Heating & Cooling
I have the same problem.
transformer going bad or bad connection check for 24v ac from red to common batteries only for mem storage and if no common used at stat to hold program red to g fan red to y comp
Jun 09, 2009 | Honeywell Programmable Thermostat Heater
Replaced thermostat - still getting red light
sounds like a faulty sender unit not passing the right voltage which is causing the gauge to read high
May 30, 2009 | 2001 Oldsmobile Intrigue
Dot1q & isl
hi,
  1. dot1q is the IEEE standard but isl is the cisco proprietary
  2. dot1q is inter operable with all other manufacturers but isl is only between cisco.
  3. Almost all the vendors started implementing dot1q
  4. cisco is going to discontinue isl in its future products.
With Regards,
TPV
Jan 25, 2008 | Computers & Internet
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
