Question about Compaq Presario Computers & Internet
Remove keyboard from presario cq81 - Presario Compaq Computers & Internet
How do I remove the LCD cable from my Compaq Presario C700? Which tape do I remove / What do I do?
You have to remove the keyboard. Most laptops have the keyboard screws at the bottom or underside of the pc and right next to the screw hole is a little keyboard picture thing or illustration that tells you that screw is to hold down the keyboard. once the keyboard is removed, you can easily get the LCD screen wires disconnected.
Aug 25, 2011 | Compaq Presario 700 470024-192 Notebook
I have Presario X6000 keyboard problems
it is doing so because of the faulty keyboard ..pls see the backspace button is stuck or not ..you can clean the keyboard by removing it ..
Thank You
Dec 07, 2009 | Compaq Presario X6000 Notebook
I went to replace the memory on my compaq presario x1000 laptop and when I opened the back panel for the memory, I only see one chip. How do I get to the other chip to replace it?
Remove the 2 screws under the laptop that are marked keyboard. There are 4 clips across the top of the keyboard. Slide these toward the bottom of the keyboard and remove the keyboard. You can now access the second socket.
Nov 22, 2009 | Compaq Presario X1000 Notebook
How do you remove the actuall keyboard on a compaq presario 1200 notebook computer, i have removed all screws and access doors on bottom end, along with the memory etc.
First remove the top plastic strip piece (where the power button is located) and then use a phillips screwdriver and unscrew the screws holding the keyboard in place. Gently pry it out and then remove the ribbon cable that connects the keyboard to the mainboard
http://www.refurbished-laptop-guide.com/how-to-replace-laptop-keyboard.html
Nov 04, 2009 | Compaq Presario 1200 Notebook
How do I remove and replace keyboard on compaq presario f730us?
Here is Compaq Presario F700 series manual.
Scroll to page 52 for keyboard removal.
Mar 28, 2009 | Compaq Presario F730US PC Notebook
I need to replace the CMOS battery in a Presario 906US Laptop
Here is service manual for Compaq Presario 900 (download parts one by one, then extract):
Part 1
Part 2
Part 3
Part 4
Mar 28, 2009 | HP Compaq Presario 906US Notebook
Need to remove my keyboard on Compaq Presario C501nr.
Remove battery.  Notice 5 phillips head screws labeled M2.5X4.  Of the 5, 2 have arrows pointing to them.  These 2 screws hold down the cover plate above the top of the keyboard, the one that has the 5 buttons for (left to right) WiFi, Power, Vol down, Vol up, and Mute.  Carefully pry up the cover after the 2 previously mentioned screws are removed.  You will see 4 screws at the top of the keyboard.  Remove these screws and gently lift up and slide up the keyboard.  Once the tabs at the bottom of the keyboard are clear, look to where the ribbon cable from the keyboard attaches to the socket on the motherboard.  Gently slide the very small tabs on the socket outward.  They only move about 1/16".  The ribbon cable should be free and you should be able to remove the keyboard assembly completely.
Install new keyboard in reverse order
Nov 29, 2008 | Microsoft Compaq Presario C501nr Notebook
Compaq Presario 2500 (2598us) loose keyboard
You might want to check the keyboard connection. It sounds as if it's not connected or seated properly.
Aug 20, 2008 | Compaq Presario 2598Us Notebook
Removal of laptop keyboard
Dear ctmom
Please find below the link to download the
HP Pavilion zx5000 Notebook PC, HP Pavilion zv5000 Notebook PC, Compaq Presario R3000 Notebook PC, HP Compaq nx9100 Notebook PC - Maintenance and Service Guide
( http://h10032.www1.hp.com/ctg/Manual/c00212209.pdf )
Removing the keyboard firstly requires the removal of the top plastic strip in order to gain access with the screwdriver to the four screws. To remove it follow the instructions at pages 137 & 138 and you are almost there.
Then on page 139&140 you will find the information to remove the keyboard. It explains all the information very analytically. You are simply unscrewing the four screws on the top side. On the bottom it is simply slided.
TIP: Be careful when you are releasing the keyboard up towards you. The flexi cable that is connected to the motherboard is quite short-fragile and does not have a lot of space to move so go slow until you have released the connector’s tabs and the cable is loose to be removed.
Please remember to remove the battery before you do any work in the laptop.
Mar 17, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
