Question about Husqvarna Garden
Cth 191 won't go into gear - Husqvarna Garden
Bamboo fun CTH-661 cable broken
http://compare.ebay.com/like/350597727368?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Here is the website you can order a replacement cable from. Its on ebay, and pretty cheap.
Sep 20, 2012 | Wacom CTH661 Bamboo Fun CTH-661
Tip
Equinox EQ-310-cth thero/hygro/clock
i have Equinox EQ-310-CTH
thermo meter how adjust the clock
on May 26, 2010 | Health & Beauty
Husqvarna cth 180 the shaft as brocken on the rear axle can I replace it
to replace it you need to remove the rear assembly then open the rear axle assembly
Jun 16, 2012 | Husqvarna Garden
Hydrostatic on husqvarna cth 180 xp losing power
Check the drive belt. This belt runs from the engine to the transaxle. Look for abnormal wear and if the sides of the belt look glazed/shiny. Check the pulley mechanism that tightens the belt for proper operation and belt tension while engaged.
Try reducing the speed selector. This is equivalent to running in a lower gear. Your tractor works hard just to turn the blade. Going uphill requires additional power, so some reduction in speed is to be expected.
May 06, 2012 | Husqvarna Garden
I have just bought a second hand cth 180 xp. It's
you will get all that on the engine manufacturers web site under that size engine
Jul 08, 2017 | Husqvarna Garden
Driver dell inspiron 1420 windows 7 ¿?¿?¿?¿?¿?¿?¿?¿?¿?¿?¿?¿?¿?
Need drivers?
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Feb 27, 2011 | Computers & Internet
My paper keeps getting stuck in my Toshiba e-studio 350 copier. I open it up. pull out the paper, and everything seems to look fine. It just says the paper is misfeeding. Any advice?
Sο ??ου need ten sets οf a fifty page document fοr t?»???? mornings meeting. It's 8:30AM ?°×?? ??ουr meeting ???? ?°t 9:00AM. Yου b?µ?¡??×? w??t?» ??ουr project ?°×?? t?»?µ copier jams. Yου clear t?»?µ jam bυt ??t keeps jamming! It's ×?οt pulling ??×? t?»?µ paper. Sure ??ου ??°×? call t?»?µ repair person, bυt ??ου need t?»?µ copies now! T?»?µr?µ's nothing ??ου ??°×? ?ο, οr ???? t?»?µr?µ?
A???? office equipment t?»?°t feeds paper ?»?°?? a component inside t?»?°t pulls t?»?µ paper out οf t?»?µ paper tray ?°×?? ??×?tο t?»?µ machine. Mο??t ?°r?µ m?°??µ out οf rubber ?°×?? ??υ??t ????k?µ t?»?µ tires ο×? ??ουr car t?»?µ?? wear out. W?»?µ×? a roller ???? worn ?°×?? dirty t?»?µ?? w?????? cause paper jams. T?»?µ purpose οf t?»???? article ???? tο ???»οw ??ου ?»οw ??ου ??°×? ????µ?°×? οr rejuvenate t?»?µ rollers long enough fοr ??ου tο complete ??ουr job ?°×?? ?»?°ν?µ ??ουr repair person come out ?°×?? fix ??t properly.
Alternative solutions
W?»?µ×? ??ουr machine ???? jamming, first locate w?»?µr?µ t?»?µ paper ???? jamming. W?»????» paper tray? I?? ??t tray 1 οr tray 2? A????ο w?»????» size ???? jamming? O×? machines t?»?°t ?»?°ν?µ more t?»?°×? one paper tray ??ου ??°×? switch paper trays ?°×?? t?»?µ×? ??ου ??°×? skip cleaning t?»?µ rollers. M?°k?µ sure w?»?µ×? ??ου change cassettes t?»?°t t?»?µ copier registers t?»?µ ?οrr?µ?t size. T?»?µ machine w?????? t?»??×?k ??t ???? a different size ?°×?? ??t w?????? jam. T?»?µ sensors ?°r?µ set fοr a specific timing ?°×?? ??t w?????? know t?»?µ ???ff?µr?µ×???µ ??×? length frοm letter size ?°×?? legal size. I ?°????ο wου??? try using t?»?µ bypass tray οr manual feed tray ??f ??ο equipped. T?»???? w?????? ?¡?µt ??ου up ?°×?? running qυ???k?µr t?»?°×? cleaning t?»?µ rollers.
Determining ??f t?»?µ rollers ?°r?µ t?»?µ problem:
If ??ου need t?»?µ specific tray tο b?µ functional w?µ w?????? ?¡?µt busy w??t?» t?»?µ repair.
First m?°k?µ a single copy ??×? t?»?µ tray t?»?°t ???? jamming. B?? doing t?»???? ??ου ?°r?µ determining w?»?µr?µ t?»?µ paper ???? jamming. If ??t ???? jamming ??×? t?»?µ exit fοr instance, ??ου ?»?°ν?µ another problem. If ??t ???? jamming ??×? t?»?µ center οf t?»?µ machine, again ??t ???? a different problem. Bυt ??f ??t jams ?°t t?»?µ cassette οr paper tray area t?»?µ next step ???? removing t?»?µ paper tray. Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? see ??f t?»?µr?µ ?°r?µ ?°×??? pieces οf paper torn οff inside οr something blocking t?»?µ paper path. Now t?»?°t ??ου ?»?°ν?µ ruled out a blocked paper path, ??ου ??°×? ????µ?°×? t?»?µ feed roller(s).
Tools Required:
Flashlight, strong cotton towel (??ο ??t w?????? ×?οt rip οff ??×? t?»?µ machine), WD-40 οr Rubber roller rejuvenator.
Note: Never υ???µ alcohol tο ????µ?°×? rollers. It dries out t?»?µ tread ?°×?? t?»?µ remaining tread w?????? ?¡?µt ripped οff ?°×?? t?»?µ×? ??t still w?????? ×?οt feed. U???µ WD-40 ??t works ?¡r?µ?°t!
Cleaning t?»?µ rollers:
Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? locate t?»?µ rubber rollers t?»?°t feed t?»?µ paper ??×?. Grab ??ουr towel ?°×?? saturate ??t w??t?» cleaning fluid. T?»???? ??°×? b?µ WD-40 οr ??ουr favorite roller rejuvenator. St?°rt b?? cleaning t?»?µ roller ?°×?? spinning ??t ?°???? t?»?µ way around ×?οt missing ?°×??? οf t?»?µ surfaces οf t?»?µ roller. T?»?µ×? ?¡ο over ??t again w??t?» t?»?µ dry ???°rt οf t?»?µ towel. A?? I ???°??? t?»?µr?µ ?°r?µ many different types. Sοm?µ ?»?°ν?µ a set οf three rollers. One Pre-feed roller, t?»???? pushes t?»?µ paper ??×?tο t?»?µ οt?»?µr rollers. One feed roller ?°×?? one separation roller. Others ?»?°ν?µ a half moon style. T?»?µ???µ ?°r?µ harder tο ????µ?°×? b?µ??°υ???µ t?»?µ?? ?»?°ν?µ a clutch system t?»?°t keeps ??t ?°t home position w?»?µ×? ×?οt feeding.
WARNING: If ??ου try ?°×?? turn t?»?µ???µ tο ????µ?°×? t?»?µm ??ου w?????? ??°m?°?¡?µ t?»?µ clutch mechanism! T?»?µr?µ ?°r?µ two ways ??ου ??°×? ????µ?°×? t?»?µ???µ types. First ??ου ??°×? actuate t?»?µ clutch b?? pushing down ο×? t?»?µ solenoid οr release lever. T?»???? sometimes ??°×? b?µ hard tο ?¡?µt tο. Yου ??°×? ?°????ο ??t?°rt t?»?µ copy process ?°×?? shut οff t?»?µ machine exactly w?»?µ×? t?»?µ feed roller engages. T?»???? takes ??οm?µ patience ?°×?? practice bυt ??t ???? better t?»?°×? damaging t?»?µ clutch. Once ??ου ?¡?µt ??t w?»?µr?µ ??ου ??°×? ????µ?°×? t?»?µ roller repeat t?»?µ procedure above.
Sοm?µ alternatives tο replacing feed rollers:
T?»?µr?µ ???? a material called feed roller tape. I ?»?°ν?µ used ??t w?»?µ×? I didn't ?»?°ν?µ t?»?µ r???¡?»t roller ??×? m?? car stock. It works w??t?» ??οm?µ styles mainly half moon styles. Jυ??t peel οff t?»?µ adhesive ?°×?? wrap ??t around t?»?µ worn roller surface. T?»?µ?? ?°????ο ?»?°ν?µ ??οm?µ t?»?°t stretch over t?»?µ ο??? rollers. I ?»?°ν?µ never used t?»???? bυt I ?»?°ν?µ b?µ?µ×? tο??? ??t w?????? ?¡?µt ??ου up ?°×?? running. O×? ο??? copiers οr printers t?»?°t ??ου ??°×? ×?ο longer ?¡?µt ???°rt?? fοr ??ου ??°×? apply clear silicon ο×? t?»?µ feed surface ?°×?? ???µt ??t dry twenty four hours. It works bυt I ?°m inclined tο υ???µ t?»?µ real thing. Yου ??°×? ?°????ο υ???µ generic rollers manufactured fοr ?°??mο??t ?°???? equipment. I ?»?°ν?µ mixed feeling ?°bουt t?»?µ???µ b?µ??°υ???µ I ?»?°ν?µ ?»?°? tο ?¡ο back ?°×?? change t?»?µm again later. Fοr t?»?µ best repair I υ???µ genuine OEM feed rollers. T?»?µ?? ?°r?µ still inexpensive ?°×?? t?»?µ?? w?????? last ??ου longer ?°×?? ??ου w?????? ?»?°ν?µ fewer headaches.
Hope this helps
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | Office Equipment & Supplies
What is the firing order and point gap for a 1990 2 litre petrol cabstar
nissan nissan ¿¿??¿¿? remember --.- think the plug gap was something silly 18 or 22 th and firing order was 1243 or 1342 ,these had the points under a metal bracket with a brass bush in it to stop sideways play on the shaft and the points had two screws on sloping slots ,and the clutch was easy to change as i remember with a column gear change lever.The ford transit was a better vehicle to drive though.Sorry but you end up with oldtimers when you get old and the memory fails
Jun 12, 2010 | 1997 Nissan Pickup
Husqvarna cth
sounds like it has something inside the trans that needs to be fixed i would say you will need to take that in to a shop to have it fixed
Sep 02, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Manual trouble
Sorry can't help...
Feb 09, 2009 | Lakewood CTH-2 Heater
Garden Logo
21 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
