Question about HP Compaq JBL Pro (401508-001) Computer Speakers
Poor sound sound is no good
What is a good Price for this secondhand instrument? SER.no. 658516
No matter what instrument you have, the price should reflect the quality of the instrument.
For instance say your instrument is very good sounding, but has some wear and tear, you could sell it for $100, if it's poor sounding
but great looks $75, and if it's poor sounding, and has wear and tear
the price should be no more than $50.
Mar 13, 2015 | Music
Stanton str-150 - poor sound from left deck
Just make sure all your connections are clean , your tt in horizontal and take a new record, set the azimututh/anti-skate right , use the channel of the deck which works correct if it doesn't you have to measure the voltage coming from the cable, since i don't believe it's the mixer. But pls describe a poor sound, that doesn't say a lot. My tables often make a poor crappy sound , with channels falling out, but that's due to dust on the vinyl and stylus(needle) or a poor connection with my sme connector and then i clean both. Does is crackle and move the rca cable when you're playing, often is that stuck , but if it's on both channels , which sometimes is hard to hear in a little room. It can't be the mixer, cause i told you to test it on the other, good soudinding mixer input. So then it can be your groundwire, There ain't much more. Good tonar, clean sme connector, clean record(take the needle from the right working table). Check if the pins in the sme connector move smoothly.
Goodluck
Jul 21, 2014 | Audio Players & Recorders
My nokia 5233 mic sound respond poor sound in other side
So many things may cause this. Contact Nokia Care.
Apr 27, 2014 | Nokia Cell Phones
Virtual surround sound 5740-5780
What do you mean by poor? is it quiet? garbled? full of static?
Apr 05, 2014 | Acer Aspire 5740-6025 Notebook
Radio does not work. turns on, seems to be working, but no sound. fuses are good.
sounds like a poorly grounded antella,or a loose connection at the back of the radio. or a poor ground supply for the radio.
Sep 02, 2010 | 1999 Jeep Grand Cherokee
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Jun 18, 2010 | Sanyo Televison & Video
Horn does not work properly sounds like a toyota horn already checked both relays.
Your vechicle only has one horn on it if it is working but has poor sound You need to ck for a poor ground or poor voltage at the horn The horn is located behind the left headlamp disconnect the horn and ck the power wire for 12 volts (green wire) then ck the black wire for a good ground 0 ohms fron the connector to battery Neg post. If these readings are correct then the horn needs to be replaced
Mar 08, 2010 | 2005 Chevrolet Equinox
Cobra 132 recieves good poor send
i would take it in and get a new diamond thats what it sounds like to me..
Dec 02, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
POOR SOUND QUALITY
get some woofers and amplifiers attached to it.they wont cost u much and u will then have an excellent sound.....
Dec 01, 2007 | Audio Players & Recorders
HP Compaq JBL Pro (401508-001) Computer Speakers Logo
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
