Question about Belkin F1DF102PEA 2-port KVM Switch
Belkin Switch2 Not Recognised at Boot Up
I have a similar problem - I have two PCs attached to a Belkin Switch2 USB KVM and neither the mouse or keyboard is recognised at boot up. The work around is to unplug the KVM USB lead from the back of the PC that I want to use and then reconnect it. At this point the PC recognises the switch and the mouse and keyboard start to work. I have installed the latest drivers, installed the Switch2 software from the Belkin web site (which is really just a soft switch), but nothing has changed. To say it is a pile of **** is an understatement. Any help greatfully received.
2 Suggested Answers
SOURCE: Components not recognised automatically with Belkin Switch2
This is not quite a solution, but a workaround. Take a USB cable extender and intercept the 5V supply wire in it (normally red) with a push to break switch. When you have powered up the PC, push the switch and the KVM will then work (same as your unplugging but much easier to do ). Switch bought on Ebay for 0.99GBP. Belkin tried to insist that I had my laptop plugged in and working if I wanted to use my desktop.
Posted on Aug 18, 2009
Hello there, I have a Lite On SK-3211 1U
This product uses none-standard USB host controller and USB devices are not being enumerated properly within KVM. The company that designed this product is no longer in business.
Currently there no support for this specific keyboard/mouse on Belkin Dual User KVM over IP.
Sep 15, 2009 | Lite On Computers & Internet
Belkin Switch Problem
no its not, sometimes that device or the port connection are not installed yet properly. To check it on the device manager, see to it that the connection on your Belkin Switch are functioning. Or try another port or USB connection, it might work there.
Jul 22, 2009 | Belkin F1DK102U 2-port KVM Switch
Feb 08, 2009 | Belkin F1DF102PEA 2-port KVM Switch
I bought an 2 port usb kvm switch. why are there 2 usb connectors on each cable what do i do with the 2nd one. model gcs22u
Pah,
The purpose for each of the USB plugs are likely 1 for your keyboard and one for your mouse to each of the PCs you attach to your KVM
Hope this Helps
Dave
Nov 06, 2008 | Computers & Internet
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
BELKING SWITCH2
I think you must also connect the USB connectors.
Jan 24, 2008 | Belkin F1DK102U 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Belkin 2-port kvm switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
Not running on startup
I occasionally have a similar problem with a couple of my KVM?s and I think it relates to the circuitry in the KVM that is supposed to fool the PC into thinking a mouse/keyboard is attached. Windows doesn?t see the mouse so it doesn?t load the drivers unless you force it. What works for me is to just start the PC and switch the KVM to that PCs port and leave it there till the computer finishes booting. Then its safe to switch to the other port, probably not the elegant solution you were looking for but it works every time.
Jun 18, 2007 | Belkin OmniView SOHO 2-port KVM Switch
Belkin F1DF102PEA 2-port KVM Switch Logo
668 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
