Question about Whirlpool GJC3034 Electric Cooktop
Whirlpool gjc3034lpo broken switch for large burner
The switch for the large burner is broken...where can I get a new one or find the part number?
My large burner at the front does not work, yet when i replace it with\r\nthe large burner at the back it does not work , yet when you put the front burner at the back it works.
Your front burner is fine. Assuming you have an electric cooktop the problem is in the switch that controls that burner. The infinite control switch. Replace it.
Dec 07, 2010 | Jenn-Air Cooktops
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
YOU DO NOT HAVE PURCHASE A NEW ONE , TAKE NOTE OF TYPE OF ELEMENTS AND ,I E LARGE/ OR SMALL, AND MODEL NUMBER AND CONTACT SUPPLIER FOR REPLACEMENTS, THEN YOU CAN TAKE OUT BROKEN ELEMENTS AND REPLACE WITH NEW ONES.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
Whirlpool GJC3034 Electric Cooktop Logo
104 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
