Question about Magnavox HDD, DVR, and DVD Recorder with Digital Tuner, 320GB
Receiving auto control signal
Picture flashing on then off and say's receiving auto control signal and just keeps repeating the same over.
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Cant get past auto scan
if auto channel scan finds nothing , then your tv isn't receiving a strong enough signal to display , and it will not go any further than that , you can though select another type input (hdmi ?) and after providing a proper signal to that input it should display that picture
May 04, 2016 | Element Electronics Televison & Video
Power light keeps flashing with no picture
What are you using for receiving a picture, cable, satellite, or direct off the air broadcast? If you use either of the first two make sure that those two devices are "ON" first or turning your set on will result in receiving no input from the receiver. Also be certain that in the menu for your flat screen that you have the correct receiver selected as the input to your tv or once again you will receive no picture.
Jan 26, 2012 | JVC Televison & Video
Panasonic TV model no TX-32PD30. Resolution has changed ie become larger and we are losing full screen picture - people are cut out of the screen.
The most likely cause of this is that you have accidentally changed the screen aspect ratio. There should be a button on the Panasonic remote marked "ASPECT". With the TV switched on, try pressing the "ASPECT" button repeatedly until the picture either returns to the correct size or you are unsuccessful and cycle back to the original picture size.
You will probably find that you are currently on one of the "ZOOM" settings. The correct setting should either be "AUTO" or "16:9".
If this does not solve your problem, please post back for further assistance. If you are using another receiving device, e.g. a Sky / FreeSat or Freeview box, it is also possible that you need to change the ratio setting of the receiving equipment. Please let me know the details of any additional receiving equipment you are using if/when replying.
Regards,
BElectric.
Dec 30, 2010 | Panasonic Televison & Video
Our Samsung remote control ARH-428 will not work. We have changed batteries however we can not make it operate our air-conditioner
If even with new batteries not working means transmission signal problem. May be with remote or receiving signal problem with indoor. Check your remote with camera mobile and press on/off switch. If it's ultra light flashes, it's o.k. Then repair receiving signal in PCB.If no ultra light in remote, replace remote.
Dec 27, 2010 | Heating & Cooling
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Keeps flashing Receive light but not connected
when the receive light blinks it means its either receiving or attempting to receive a signal. If its not connected with the ethernet cord then its trying to receive and find the signal from your ISP (internet service provider).
Apr 28, 2010 | Arris SURFboard SB5101 Cable Modem
The main picture screen is not receiving the cable signal. Only the PIP search frame is receiving cable signal but it's stuck on channel 3 and cannot change channels. I've tried doing the auto scan for ALL...
either you don't have your cable connected to the right spot or your main tunner has failed check your cable connection also try to swithch the pip input to the main see if that works
Dec 09, 2009 | Televison & Video
Signal Problems
DVD RECORDER. AUTO SET UP WILL DOWN LOAD
AND RECORD BUT HAVE TO USE AUTO SET UP EVERY TIME
I WANT TO RECORD
Oct 27, 2006 | Philips 32PF5320 32 in. HD-Ready LCD...
Magnavox HDD, DVR, and DVD Recorder with Digital Tuner, 320GB Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
