Question about Sewing Machines
Install bobbin case singer excelle 6212c - Sewing Machines
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
Posted on May 11, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
chrismyers67
  • 53 Answers
SOURCE: how do i replace the bobbin case in singer machine
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Posted on Jun 07, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
How to thread bobbin on Singer Serenade 30
The owner's manual should have instructions. Otherwise, search the internet for videos/tutorials for using your machine, ie:
Inserting the bobbin on Singer sewing machine
How to set up singer sewing machine MP4
Machines vary on how the bobbin is installed. A lot of Singers have a drop-in bobbin, but others actually have a removable bobbin case. Just search until you find one that is similar to yours.
Feb 14, 2016 | Singer Sewing Machines
Singer 4622 installing bobbin case
Also search for some videos on YouTube:
Bobbin case seating 2
Inserting Bobbin Top Drop In
Fixing Top Load Bobbin
Jan 22, 2016 | Singer Sewing Machines
Needle is not catching the lope. This is singer 6212C. Needle bar has 3 marks,which one do I use no setting the needle high?
The eye of the needle should be just above the hook of the bobbin rail at it's lowest point. If you have more questions than that and need more specific help try talking to the people at the link that I attached. They are great to work with. Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Jan 31, 2015 | Singer Sewing Machines
Install bobbin case
Watch in utube for 'singer front loading bobbin case' and other links that can be helpful to you.
Nov 07, 2013 | Singer 8280 Mechanical Sewing Machine
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Apr 10, 2009 | Singer Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
