Question about Bosch Classixx WFL 2066 Front Load Washer
My machine taking in water but drum not moving
Power is on and seems fine but no movement is the drum motor gone faulty
  • 118 Answers
Hello when you start the machine do you hear clicking from control board if do all you need to do is replace the carbon brushes on the motor. They are cheap to get does require removing back pannel I found better to remove motor easy access hope that helped :)
Posted on May 07, 2014
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Bosch Washing Machine model WFG2460 drum doesn't turn
There is no start capacitor on this washer if it has brushes in the motor, most likely the prob is due to worn brushes, to check them, do the following.
Remove rear panel, remove belt, remove motor plug.
Undo 2 screws securing motor, lever motor back with a screw driver or similar, keeping hold of motor and remove motor,.
You will find the brushes at the opp end to the motor pulley, replace if less than 1cm in length.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
  • 491 Answers
SOURCE: THERE IS POWER TO MY BOSCH 1200 W/MACHINE AND IT
IT SOUNDS LIKE THE DRIVE BELT HAS BROKE, IF YOU CAN BUT FIRST MAKE SURE THE POWER IS OFF REMOVE THE PANNEL AND LOCATE THE DRIVE BELT TAKE THE BELT TO A PLUMMERS SUPPLY STORE FOR A REPLACEMENT AS IT WOULD HAVE THE PART CODE ON IT THEN REPLACE THE BELT AND YOUR MACHINE SHOULD VWOOK FINE , GIVE IT A GO YOU CAN LEARN .
Posted on Nov 16, 2009
HansPP
  • 2510 Answers
SOURCE: my front loader fills with water, pumps and drains
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
Posted on May 21, 2011
My lg washer, wm2277hw, has the LE error code, so how do I manually make it spin to extract the water.
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG WM-2277HW Front Load Washer
LG WASHER WM0532HW, ERROR MESSAGE LE WATER INTAKE ERROR
Hi
Daniel
Aug 08, 2011 | LG Washing Machines
Have l g tromm # wm2277HB drum stoped truning and code on front says L E
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. --------------- Unplug the unit from main outlet.Then drain the water from the machine.By disconnecting the drain pump ,There will be too much water so be care full.If you disconnect the drain pump from drain hose to drain the water it will flow on you,so keep towels ready to soak the water. Also clean the water filter. ----------------- In most of the case LE error is solved by just disconnecting the washing machine from main power outlet for 30 minutes.But if the problem is still the same then try cleaning the filter and draining the water from drain pump.This error occurs when motor stops functioning and water does not drain. --------------Also another cause of LE error is Regarding the LE ERROR CODE. This code is also caused by having a residue on the sensors in your unit. You have to use a HE liquid detergent.If you use fabric softener use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vine-ager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE. ---------------- This should help.Thanks.Helpmech,.
Mar 25, 2011 | LG Washing Machines
Washer won't spin - reading LE - clothes sitting in puddle of water - researching and wondered if it's a censor switch ??
Hi
Daniel
Feb 11, 2011 | LG WM-1832C Front Load Washer
Error reading LE. How can I fix this without calling repair guy. Washer spins but once the water is inthe machine it will not spin.
Hi
Daniel
Jan 26, 2011 | LG WM1814CW Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Hi,we have aBeko WMA 1512 Eco case washing machine,it is coming up for 2yrs old. It will take on water and the control switche moves as required to empty, but drum does not move,it's like it goes through...
I suggest the next step is to check the motor brushes. Take belt off and undo bolt at right hand side of motor .Allow motor to pivot down and then pull to remove. Brushes are located at back of motor in plastic housings. If worn down to housing they will need replacing. Any problems dont hesitate to ask.
Nov 16, 2008 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
