Question about Bosch Washing Machines
Wfd 2473 does this machine have a quick wash????
3 Suggested Answers
  • 49 Answers
SOURCE: Bosch washing machine not getting hot
one of 2 things, eather the element is faulty or the electronic control board wich puts power to the element is faulty.
more likely to be the element
Posted on Feb 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch WFD 2473 - wont spin. I've taken out the
Even if the pump is not working, then so long as there is no water in the washer, it should spin
If it does not, then I would suspect the motor brushes are worn out.
You need to remove the motor to check the brushes, if they are less than 2 or 3 mm long then they need replacing.
I do not think the washer you found is off the pump,more likely out of someones pocket.
Hope this helps with your problem.
Posted on Dec 02, 2009
Testimonial: "Thanks - will try that now! "
Fax to 1-815-346-2473 on my SF 650 machine?
Dear
first check the no 1-815-346-2473 with your telephone company. In the said model there is a handset. do -lift hand set here the companys dial tone dial the required tel. no. here the Rx.tone from the other fax machine connected. If its working definitely your fax machine will transmit the data.
If the fax machine has connected behind EPABX, it has unique no. to dial out side of the epabx. In that case contact your EPABX provider to program the fax machine.
Thanks.
Dec 18, 2014 | Samsung SF-650 Laser Fax Machine
I have a bosch wfd 2473 washing machine it will not pump or spin, i have removed the water by releasing the filter there is nothing within the filter and the pump spins quite freely .i could not syphon the...
bosch wfd 2473 washing machine it will not pump or spin This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 27, 2012 | Washing Machines
Bosch WFD 2473 - wont spin. I've taken out the filter and found a broken washer in it. Can't work out where the washer comes from? Doesn't seem to fit the filter. Having cleaned the filter, washing machine...
Dec 02, 2009 | Bosch WFL 2063 Front Load Washer
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Feb 21, 2008 | Bosch WFL 2063 Front Load Washer
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
11 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
