Question about Nikon COOLPIX Cameras
Nikon coolpix l830
When i zoomed in into captured images from my camera it automatically came to 0x level of zoom
  • 6 Answers
SOURCE: Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
 John.
Posted on Oct 16, 2007
Roynice152
  • 88 Answers
SOURCE: dropped camera jammed zoom lens on nikon 28-85 lens
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Posted on Jan 09, 2009
  • 11967 Answers
SOURCE: Everytime I zoom in or out I get a lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 05, 2010
lock123
  • 6831 Answers
SOURCE: my nikon coolpix says lens error when ever i try
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
lock123
  • 6831 Answers
SOURCE: my Nikon Coolpix L100 flashes a lens cap error
Hello
Regards
Andrea
Posted on Sep 30, 2010
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
Why does my Coolpix overexpose images when zoomed in?
If you zoom in then press the shutter down halfway. If you zoom with the shutter pressed half way you can get an over exposed image.
Aug 04, 2014 | Nikon Coolpix 4300 Digital Camera
I am thinking of buying a Nikon Coolpix S3000. I have been reading some of the reviews of them and now I run across your report on how to fix the camera. I am a little worried in buying one now. It there...
I would recommend you to buy Nikon Coolpix S4000 Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touch You can check out more detailed review for Nikon Coolpix S4000. http://hubpages.com/hub/Nikon-Coolpix-S4000-12-MP-Digital-Camera
Dec 21, 2010 | Nikon Coolpix S3000 Digital Camera
Want to buy pentax m40 camera
I would suggest to buy Nikon Coolpix S80 14.1 MP Digital Camera with 3.5-Inch OLED Touchscreen and 5x Wide-Angle Zoom Nikkor ED Lens.I have used this camera and it performs really well. http://hubpages.com/hub/Nikon-Coolpix-S80-141-MP-Digital-Camera
Jun 29, 2010 | Pentax Optio M40 8MP Digital Camera with...
In the process of buying a samsung l301 camera. how many photos can you take?
I would recommend you to buy Nikon Coolpix S4000 Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touchYou can check out more detailed review for Nikon Coolpix S4000. http://hubpages.com/hub/Nikon-Coolpix-S4000-12-MP-Digital-Camera
Jan 30, 2010 | Samsung Digimax 301 Digital Camera
If I buy a used camera do I need the cd-rom to upload the pic takened by the camera to my cpu
Dec 18, 2009 | Nikon COOLPIX L10 Digital Camera
I am buying a Canon SD970 IS digital camera. What
I would recommend you to buy Canon PowerShot SX210IS 14.1 MP Digital Camera with 14x Wide Angle Optical Image Stabilized Zoom and 3.0-Inch LCD. Decidedly slim and sleekly refined, the PowerShot SX210 IS packs a feature set that reads like a wish list. The 14.1 Megapixel CCD joins a 14x 28mm Wide-Angle Zoom for imaging power to spare. Frame your shots in the bright 3.0-inch widescreen PureColor System LCD, with the Low Light mode for sharp images in dimly-lit situations. It also captures stunning HD movies with Dynamic mode for enhanced image stabilization when shooting movies using wide-angle settings. Capture smooth HD video (720p) with stereo sound for a truly natural, high-quality HD experience. The PowerShot SX210 IS not only goes wherever you do, but takes your photography and video to a whole new place, too. You can check out more detailed review for PowerShot SX210 IS http://hubpages.com/hub/Canon-PowerShot-SX210IS-Digital-Camera
Nov 16, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Nikon S210- Coolpix 8.0-Megapixel Digital Camera - I want to buy this model...please can you help me out to buy it.
Sep 29, 2009 | Nikon Coolpix 8.0-Megapixel Digital Camera...
Nikon Coolpix 5700 Over-exposure of image whilst zooming in brigh
I now have the exact same issue. When not zoomed or fully zoomed the exposure is correct, however when partially zoomed the aperture does not engage and stays fully open. So basically I cannot really use the zoom or the picture is over exposed. Note - actually about 2/3 mechanical zoom and on works, so I can use a bit of the zoom.
Suggestions?
Sep 20, 2009 | Nikon Coolpix 5700 Digital Camera
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Jun 22, 2008 | Nikon Coolpix 4300 Digital Camera
Cameras Logo
24 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
