Question about Hobart Convection Oven Countertop Electric Model Cn 85
Installed new lamps in hobart convection oven, none of the (4)
Lamps will work. lamps have been inop for sometime
  • 23 Answers
The lamps are wired in series, if one lamp is bad, none will work.
Posted on Feb 19, 2015
Convert from natural gas to propane on a hobart hgc501 convection oven
You should be able to purchase a conversion kit from Hobart Direct or a Hobart Agent. The conversion should be done by a Licensed Gas Fitter.
Oct 01, 2015 | Hobart Kitchen Ranges
Hobart convection oven
You either have something hitting the convection blower wheel or the bearings in the convection motor are shot.
Feb 17, 2014 | Ovens
How do I fix hobart convection oven door chain
Check the bottom hinges, one of them should have a roll pin, the pin might be broken
Oct 03, 2012 | Hobart HEC202 Electric Double Oven
Hobart electric convection oven model #cn90 ser. # 07-007-968-nj
Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
Apr 09, 2010 | Hobart HEC501-240V Electric Oven
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Sharp 1874- Door seems to "jar open" and oven stops
if you have a warranty get a new one installed they have to honor your warranty or better yet if they want payment you want new unit sometimes they come deffective from the factory ad you may have gotten one of them
Feb 20, 2009 | Sharp R-1874 Convection/Microwave Oven
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Oven shuts on & off: Control panel inop at times.
I've been battling with on and off inop problems on the controls of my range. sometimes a good cleaning or turning the circuit on and off has worked, but recently the start button and 1 of the burners stopped working. after surfing through many forums with the same problems, i found 1 with some solution advice that worked great so i decided to revisit some of the sites i surfed for info the forward the advice.....
the ribbon circuits get dirty and simply need tp be unplugged, wiped clean and reattatched. after doing this, my oven is good as new...i hope this helps:)
Jun 18, 2008 | LG 30 in Kitchen Series Dual Convection...
Hobart Convection Oven Countertop Electric Model Cn 85 Logo
63 people viewed this question
Top Hobart Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Hobart Kitchen Range Expert? Answer questions, earn points and help others
