How to Load Paper Roll in Brother Phone Fax-520DT
Need help to load Thermal paper roll
  • 9 Answers
SOURCE: how to load paper
Just put the thermal paper(paper roll) inside the machine and the SHINNY side of that thermal paper would be on the Top side where the thermal unit is place or vice versa.
Posted on Dec 30, 2007
  • 168 Answers
SOURCE: Load new reel of paper
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Posted on Feb 10, 2008
SOURCE: problem on printing on a thermal paper (Fax Roll Paper)
Laser printer CAN'T print on thermal papers! Lasers printers use a heat source to fix the toner in the paper, and that same heat source turns the thermal paper black. In one word, you CAN'T use that kind of paper unless you disable the heat source, and in that case you won't be able to print on normal paper and the toner won't fix on any kind of paper!!!
Posted on Mar 16, 2008
Stickx
  • 148 Answers
SOURCE: wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Posted on Jun 27, 2008
leroyal
  • 2120 Answers
SOURCE: Which way to laod paper to fax on Brother 560 plain paper fax
Does not matter.
If you mean when sending, make a copy, then you'll be sure.
Posted on Dec 16, 2008
When I try to make a copy in My fax sharp ux-108 the paper goes out blank
First make sure the original document is loaded with the correct side facing down. If not the problem try taking out the roll paper and reload it with the other side of the paper facing up
Jan 23, 2012 | Sharp UX 108 Roll paper Thermal Fax
Want to know how to load thermal paper on my sharp Fax model FO-71
1 - Grasp the finger hold and pull up to open the operation panel.
2 - Flip up the front paper guide.
3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
4 - Unwrap the roll of thermal paper and insert the paper shaft.
5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
• Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
come out blank after printing.)
6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
7 - Make sure the paper comes out straight, and then flip down the paper guide.
8 - Close the operation panel, making sure it clicks into place.
• FO-71: A short length of the paper will be cut off.
Dec 01, 2010 | Office Equipment & Supplies
User´s guide
HELL, MY NAME IS STEVE, YOU ARE INTERESTED IN A OP MANUAL FOR THE BROTHER FAX 275 YOU CAN EITHER ORDER IT DIREC FROM BROTHER AT 908-704-1700 OR GO TO BROTHER.COM AND DOWN LOAD IT.
Jan 15, 2009 | Brother Personal FAX-275 Roll paper...
Panasonic kx-fp155 not printing
problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
I need to know how to use my fax machine it is a brother personal 275
what is it that you need to know? you should go to brother.com and down load the manual it is free brother tech
Dec 10, 2008 | Brother Personal FAX-275 Roll paper...
I need to print instructions on how to use a brother fax -645 machine. how to set and send faxes
An on line manual probably does not exist. Put paper in feeder face down, dial number, press send.
Sep 11, 2008 | Sharp UX 108 Roll paper Thermal Fax
Muratec M2500 Fax
M2500 is an older thermal paper machine. Release lever for top cover is on RHS of machine. Top cover opens. Install roll of paper into machine so that the paper comes forward over the top of the roll. and is then fed out the front thro' the cutter mechanism.
Manual can still be downloaded from Muratecs web site for FREE. www.muratec.com under Legacy fax machines.
Feb 22, 2008 | Muratec M2500 Fax
Help, cant use it !!
The roll of thermal paper can print only on 1 side. make sure the roll of paper is in correctly.
Jan 20, 2008 | Philips PPF-531 Plain Paper Thermal...
How to load paper
Dec 30, 2007 | Sharp UX 108 Roll paper Thermal Fax
15 people viewed this question
jasbo
jasbo
