Question about Sharp Office Equipment & Supplies
Error code ch sharp ar 5015 - Sharp Office Equipment & Supplies
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
  • 255 Answers
SOURCE: ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Posted on Nov 24, 2009
Error code CH ON SHARP 5015
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm550n_m550u_m620n_m620u_m700n_m700u.pdf
Apr 29, 2015 | Sharp Office Equipment & Supplies
Tip
How to clear code H4 in All sharp copiers.
All the sharp copiers reset by code 14.
type of codes entry:# interrupt C interrupt.led goes off,press 14 and start.
2`nd type:(# * c * ) 14 start ( M 207 model)
3`rd type: C interrupt 0 interrupt (almost for analog copiers)and AR-161 .AR - 5015
on May 30, 2010 | Sharp AR-5320 Black and White Copier
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
Error code h-3 on my sharp ar 5015
Basicly, you have a problem with the fuser unit.
Aug 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR 5015 has 2/U error Please help me to solve it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} CRUM chip communication error
Aug 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error code ch
CH mean any kinds of door is open or not close properly.Please close door properly.right side or front side.it has a connector switch it is open or displace.
Dec 15, 2009 | Sharp AR-5320 Black and White Copier
Ar-5316 showing error ch
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Our Sharp AR-N275 copier is displaying error code "CH" (steady, not blinking). What does it mean?
Hello sir; CH it means somewhere the door is open, check it out all the door inside and outside.
Sep 30, 2009 | Sharp AR-N275 Copier
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
