Question about Whirlpool Heating & Cooling
Whirlpool ac icing inside the ac and no good cooling
    Guru:
  • 587 Answers
You are either low on refrigerant, dirty coil or filter not allowing the air to flow through the coil, indoor blower motor not running or bad blower motor capacitor if it has one.
Posted on Apr 20, 2014
My whirlpool gold refrigerator will not cool. Only the bottom freezer works
Sometimes when the freezer door is cracked open a bit for too long, ice forms inside around the vent. I believe the fridge is cooled by the freezer air coming through that vent. Defrost the freezer completely, about 36 hours, and wipe it around till it is clean and dry. Then turn it back on and just wait... My Maytag fixed itself that way, and it took a few days to get cool to temp again..... Good Luck!
Feb 03, 2016 | Whirlpool Refrigerators
Why is my brisk air duo therm rv ac freezing up on the inside.
Where you see frost all the time, wait for unit to thaw and start cooling again and carefully slide hand up in that hole and see if you can feel cool air leaking in from divider that separates cool and return air, that will cause freeze-ups as well. Use foil tape if necessary to stop any cool air coming in to return air from around divider. Also, if you have any diffusers closed, (on ducted system in ceiling) or partially closed, open them all up full flow. If you restrict the cold air from coming out too much, it can also cause freeze up. One more thing, take cover off where cool air box is and double check that something isn't restricting the flow of cold in to the duct work if it has ducted system.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
Hello ... i got a one year old AC haier esa3105 and i got a problem; the air is not cold its kinda cool but nothing compering to when it was new. i set it up to go down to 61F lowest temperature on the...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Heating & Cooling
NOT MAKING ICE
Contact technical support from user guide about freezing functionalities. Possibilities are that the regulator on the inside of the side compartment is regulated to cool water and not form ice. Observe the termostate from the interior of frege ans set o cool
Dec 03, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ac fan speed
Replace the blower motor resister,this is the speeds for the blower motor,it is located very near the blower motor,and is mounted on the blower box,and it actually goes inside the box,to keep it cool.The reason for it`s failure is the blower motor,even though the blower motor sounds,and runs good,it is drawing too many amps.If this was at all helpful,please rate,thank you.
Jul 27, 2010 | 2001 Ford Expedition
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Heating & Cooling Logo
32 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
