My jvc has developed a tracking problem when viewing tapes recorded on other recorders. I cant seem to correct the problem. It shows old tapes without a problem
VCR tracking has to be set up right, but even then many machines have problems with tracking other vcr's tapes. Generally a good quality commercial tape should track well. If it doesn't then either there's a fault with the tracking on your machine or the tracking is not set up right. Most tracking problems are caused by dirt, or wear on the heads or surfaces. Give your VCR a good clean up, every surface the tape comes into contact with, using Servisol Video 40. If that doesn't solve it you might have to look into the cost of replacing heads, maybe the control/audio head first. Or you should look at having the tracking set up by a proffessional (at a JVC service center). However if the tracking was off, after resetting any tapes the machine has done, may now have problems tracking, whilst other machines tapes and commercial will track normal.
