Bose wave III clock losing time
My new Bose Wave III is losing time on the clock. The display will read "Please Wait" as if it was powered back on, and then loses time on the clock.This happens several times a day while plugged on, but not when playing the radio. I have checked the chord connection and outlet connection, unplugged and replugged and lastly a reset to factory settings. Nothing helped.
  • 5 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
BillB-SA
  • 2761 Answers
SOURCE: Bose wave radio won't turn on
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monpoly on repair of these units. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to provide a $200 allowance towards purchase of a new Wave. Before you spend the big bucks on theis trouble-prone product though, you might want to check out the new HD radios -- better sound and MUCH lower prices than Bose.
Posted on May 22, 2009
DigidocTN
  • 22 Answers
SOURCE: 120v Bose Wave Radio/CD player plugged into 240V outlet
There is a fuse you can check. Also a rectifier bridge, a 3 terminal regulator IC (18V in, and 10V out) as well as a small transistor Q1 which often shorts. Easy and cheap fixes, or I would offer to buy your non-working model Bose if you decide to sell it.
Posted on Jun 30, 2009
  • 68 Answers
SOURCE: my bose wave radio won't turn on at all. replaced 9 volt battery.
open unit up and check A/C FUSE located near where the A/C plug/wire is connected to radio!
If fuse is bad it will measure an OPEN ]---- ----[
a GOOD FUSE will measure a SHORT ]-----------[
gl
Posted on May 19, 2010
  • 13 Answers
SOURCE: My bose wave radio wont turn on. It has no power
I have the exact same AWR1-1W model for repair last week. I am assuming you have a meter and you also have soldering skills here.
You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
Posted on Jun 07, 2010
Bose Wave Radio/CD clock running very slow. Now that I've moved it across the pacific ocean(US to NZ) the clock is suddenly running very slow, losing 10-15 minutes per hour while running on any...
My guess is that the clock in the radio is based off of the AC line frequency (not voltage). In the US the line frequency is 60hz (hertz). I'm guessing that the line frequency in NZ is 50hz, which would seem to explain that extreme amount of time loss. I would check with Bose, but I'm betting they make different 50hz models for export.
May 16, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
Bose Wave unplugged now it won't power up when plugged back in
I will first start check the power section circuitry of your Bose Wave radio. Are you electronics savvy?
Jun 16, 2009 | Bose Wave Radio
May 15, 2009 | Bose Wave Radio
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
Bose not working at all
Unfortunately, Bose will not release their schematics of parts lists, effectively giving them a monopoly on repair of these sets. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Jan 28, 2009 | Bose Wave Radio
Bose wave no sound
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. According to their web site, www.bose.com, they will repair most Wave radios for $100 or give you $200 credit towards the purchase of a new set. Check your options before you spend the big bucks though. A new HD radio, with better sound and a MUCH lower price, might be a better choice than repair of a problem prone Bose.
Bill B.
Jan 26, 2009 | Bose Wave Radio
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Nov 06, 2007 | Bose Wave Radio
Bose Wave Radio
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to give owners of broken sets a $200 allowance towards the purchase of a new Wave. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price.
Mar 05, 2007 | Bose Wave Radio
32 people viewed this question
 Grubhead
Grubhead
