Question about Microsoft Office Professional 2007 Full Version for PC
Cursure when i open a word document the cursure start from half of word document so how can i solve this problem
Linkid 104288 Problem Event Name: BlueScreen OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033
Hi Vasava,
Before solving your problem.
Q.1. Is it only happening for this single document? Try to open other documents too. If you can open other word docs, you can eliminate the issue with Win Word application problem. The problem is in your document itself. If you can't open any other word docs, than this is the application problem.
Q.2 This is for Win Word application problem. Can you find "Microsoft Office Application Recovery" under "Start menu-->All Program-->Microsoft Office-->Microsoft Office Tools". Try recovering your application with this tool. It solve my problem with Ms Excel.
Q.3 Do you have Ms Office setup cd with you. This is if the above 2 fails. You will need to reinstall Ms Office.
My guess for you problem is, you have a defected document file.
Please try the above and let me know, if I can help further.
Sep 23, 2013 | Computers & Internet
The cursor will not move and I cannot use the laptop at all.
The cursur moves from the sensory pad, if the pad went out the cursur will not move.. I would start by installing an external wireless mouse or even a basic plug in mouse to the usb port and see if you can cntrol the cursor then. Cheap wireless mouses with a small included usb donggle can be used in place of the sensory pad cursor
Oct 07, 2012 | Computers & Internet
I set something up to print and it only prints a half a page
Can you save your document to PDF and try to print it again? Sometimes there is 'corrupt' postscript information in your file, and when you make a PDF first, it will be solved. If you do not want to make a PDF first, try to print your document page by page. It also could be a memory problem. That sometimes will be solved by shutting down your printer, wait a minute than switch it on again. So, you can try these three things:
1: Shut down your printer, wait a minute switch it on again, than try to print your document
2: Print your document page by page
3: Make a pdf of your document first, than print the pdf
Succes!
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
When i email scanned docs from my HP officejet 8500 Plus printer to my email, the pdf's are too large. how do i set them to be emailed at a smaller size.
No problem, you can solve this problem very easily :
Whenever you scan a document directly to your e-mail in a PDF format then printer scans it using its own property and only scans the document without any editing in the font or characters.
But the output i.e. the scanned document in pdf shows the same text using its own properties. That font is selected by pdf and not by the hp software.You can open the scanned pdf file and manually change the font size.
Or else
The best way that I will suggest you :
- First scan the documetn in a pdf file or any format on your computer instead of directly on e-mail.
Because when you scan it to your computer printer will scan the document directly to computer and in this way after scanning you can open and see the document. You can make sure if it is scanned properly or not, however when you scan it to e-mail there are chances when we dont verify if the document is scanned properly or not. If there is any hardware issue or any other error then it will scan half page or a blank page....we wont be able to verify it.
- Also if it is an official document which is half scanned or has some problem in it will give a bad impact on the receiver which is not good for professionals.
- By scanning on computer you can verify the document, can make required changes and will be able to send the document in a proper way. It is going to take few seconds but results will be fruitful....try it..!!! I do the same way and there is not much difference
Feb 26, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Cursur jumps around while typing documents
use usb mouse for the mean time then
download the latest drivers and software for your touchpad from this website
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN365E&upd_id=3049&os_id=28
uninstall the drivers and the software for your touchpad and restart the computer
after the restart install the new version of touchpad drivers and restart check if its working.
hope this help
Sep 07, 2010 | Sony VAIO VGN-N365E/B Notebook
How do i make a booklet?
Select BOOKLET function, found in SPECIAL FUNCTIONS. Select which size paper is required and then select FINISHER to select STAPLER and SADDLE-STITCH, then load your document into the document feeder. Select number of copies then press start button. All of this is only applicable if a Finisher and Auto-Doc Feeder is installed. Let me know if this helps?
Mar 14, 2008 | Canon imageRUNNER C3220 Color Copier
Microsoft Office Professional 2007 Full Version for PC Logo
12 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
