Question about Frigidaire FD5125 5.5 Liter Stand Mixer, Meat Grinder & Blender 220 Volts"
My new fd 5125 not starting what is the possible proplems ??? Its first time i am using it .... I bought it from kuwait and transfer it to another country where no dealler for it .... Please any one answer me
How do I transfer my new password to my new ipad as I cannot use
You cannot transfer a password. Each device has its own password. If it was possible to transfer a password, any stranger from another device could transfer their own password to your ipad, then you would be locked out of your own personal ipad.
Mar 09, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
Tip
Old school proplem solver
ok this can be applied to just about any vehical ever made ...but my experience is with ( for this case) my 1991 jeep cherokee..i had all kinds of proplems and codes...they consisted of hard starting, reving up and down, cutting out,(engine dying), worse and worse gas milage..stumbling..o2 sensor codes( fault o2 sensor)..bad isc motor..bad map sensor...bad temp/thermostat and my brakes kept getting worse..(softer and softer...so i started posting my proplem all over the net and even broke down and took it to a jeep service center...i spent well over seven hundred dollars and still most all of the proplems remained...so i referd back to an old and very simple way to search for proplems with any motor...(cheapest way first)...lol well i guess not first..at least not for me haha..i started unpluging the different sensors while the engine was running to see if there was any change and every one seemed to change things a little ...so i then took a can of carb cleaner and started spraying ever gasget surface and vacume hose...!!!!..i found that the engine changed pitch every time i sprayed the intake gasget...!!!..so i bought a new one for ten dollars ...spent 4 hours to replace it .. and it fixed every one of the proplems i had...it sounds crazy but if you put a little thought behind it ..it makes perfect sense...o2 was reading faulty and lean(more oxygendue to leak)..brakes were getting softer(due to drop in manifold vacume) map sensor was reading faulty and causeing stumble and cut out (also due to drop in manifold pressure) temp/thermosate reading due to idle air temp (which needs to coencide with temp sensor) not recieving proper air flow reading also due to leak...well as much as i can go on about this i am just posting this where i can i hopes that my adventure saves someone a little money....remember i spent over 7 hundred before figuring out this simple ten dollar fix!!!! and since the intake and exhust share a common gasget it is pron to leaks....good luck and i hope this helps
on Jan 14, 2010 | Jeep Cherokee Cars & Trucks
I have a Powerware 5125 that I just replaced the batteries on. Now I get NO power to the unit when trying to turn the unit on. I put the original batteries back in and the same thing is happening. All...
I urge you to contact Eaton: Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com They bought Powerware about 6 years ago and have a full team of service personnel familiar with the 5125.
Jun 08, 2011 | Powerware 9120 UPS System
I moved a small refrigerator from one room to another, worked fine in first room, but now it will not get cold at all. Power does work, as the light is on inside. I am in Kuwait, so this a 240v model.
Possibly the fridge was moved horizontally instead of keeping it vertical. (Always keep fridges upright when moving them!) This can transfer liquid refrigerant into areas of the system in which the refrigerant is supposed to be a gas. Try unplugging it and leaving it to settle for a few days, hopefully the liquid refrigerant may drain back to where it should be. Otherwise, you may be up for a new compressor.
Mar 01, 2010 | LG Refrigerators
Sony TV not turning on!
this is almost certainly a ht proplem chech ht transistor by removal then turn tv on it should if so replace transistor be carfull high voltage may be still present on capacitors
Mar 30, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My 2006 kx450f will not start.
Compression release not fully closing? You have spark and you have air. Fuel is the unknown. Drain the carb float bowl. Now remove the water trap ( if the bike has one ),at the base of the fuel valve. Clean it out and try to start the bike after fresh gas fills the float bowl. You may want to give the air cleaner a shot of starting fluid.
Let me know what happens.
Mar 24, 2009 | 2006 kawasaki KX 450 F
The lid of my Dell Inspiron 5125 has cracked and I have bought a new one. I have been unable to find instructions for changing it - can anyone help?
The Dell Inspiron 1525 Service Manual can be found HERE. Just download, unzip, and run index.html. You should be able to find your way around from there.
Mar 10, 2009 | Dell Inspiron 1525 Notebook
Video bought in carribean
dvd payers and discs are set to work depending on the region of the world they are sold ...
goto this site and try to find your dvd model ..but remember if you cahnge the region to kuwait , it might not then play the ones set for your region
http://www.dvdcodes.net/
Jan 02, 2008 | Televison & Video
If you got the video recorder in another country you need to check to see what it uses to scan NTSC or PAL because Kuwait is a Country taht uses PAL and if you have a vcr that uses NTSC it will not play those cassettes. Let me know where you got your camcorder from if its not on this list maybe i can find out for sure if it is NTSC or PAL. Here is a list of some countrys that use NTSC and PAL
www.terrascope.org/NTSCvsPAL.html
Jan 02, 2008 | Microsoft Xbox 360 Console
Frigidaire FD5125 5.5 Liter Stand Mixer, Meat Grinder & Blender 220 Volts" Logo
379 people viewed this question
Top Frigidaire Home Experts
john h
Tom Chichester
Are you a Frigidaire Home Expert? Answer questions, earn points and help others
