Question about Pool & Spa
I have spa quip sp1200 hot tub I have no display at contoller I have 240 volt any ideas
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Check inline fuses then check transformerfor voltage follow schematic to where voltage dies
Posted on Jun 10, 2014
  • 246 Answers
SOURCE: our heater show's Eo4 never gets hot
lol but u never clean t burners
Posted on Sep 14, 2009
  • 366 Answers
SOURCE: How do you replace a flow switch in a spa, or hot tub
turn off the power to the spa. remove the cabinet under the topside remote to expose the equipment compartment. You should see the flow switch, it's usually a threaded 3/4" plug with a single grey wire coming out of it. Most of them are threaded into a tee or a special transparent fitting. If the water level in the spa is above the flow switch, you may have to drain the spa down unless you're very fast about getting the new switch in. Unthread the old switch and thread the new one in. Follow the wire on the old one to the spa pack. You'll have to remove the screws on the cover to expose the circuit board. Follow that wire into the spa pack to see where on the circuit board that it is plugged in. It may be good to run the new wire to have in place as soon as you unplug the old one you can install the new one with no question as to where it plugs in.
Reinstall the cover on the spa-pack and turn the main power back on. Make sure that the arrows on the new flow switch are facing the correct direction (direction of flow). Once you have the spa on and it starts back up, run everything to check for leaks and proper operation. If the flow switch was the only problem, all your faults should be cleared and you should be in good shape. If there are no leaks, you can reinstall the cabinet panel.
The new switch should already have teflon tape on the threads, if not, use teflon tape, apply the tape in the direction as if you were threading a nut onto the threads. You only need a few wraps of teflon tape, too much can crack the fitting you threat the new flow switch in to.
Posted on Nov 07, 2009
SOURCE: Spa Quip Err8
An error code will come up if the sensors in the unit detect no water flow, or over temperature. Now this might be the actual problem or the sensors or circuit board may be faulty. First check the pump is circulating the water, if it still errors then the fault is in the electronics.
David. Goulburn Pumps
Posted on Nov 08, 2009
john224
  • 1378 Answers
SOURCE: pool heater thermostat lights up but water do not
There should be a large, easy to read diagram under the cover once you remove it from the heater. Is the one under your missing or unreadable? Hayward doesn't publish one on their tech website or residential documents page so I have an email into our tech support contact asking for one in case yours is missing. If you find it under the cover please add a comment to that effect. FIXYA website has not been letting me post pictures lately so getting you the info may be a little difficult.
Posted on Dec 29, 2009
  • 111 Answers
SOURCE: Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
Posted on Feb 20, 2012
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
When the pump goes into high speed, it draws too much power(dims the lights) but maintains the lower speed. When the pump button is held down to shut off the system, the readout says off but the pump...
most tubs this size are fead with 240 volts power , im betting yours is . the symptom you describe is a condition that would occur if only 120 volts (half power) were reaching the tubs controller
id have a pro pool tech confirm this as water and power are dangerous to mess with if your not 150% sure in how it works
Sep 04, 2013 | Belize Spas Belize Oval II Hot Tub Spa -...
Spa quip hot tub error code 07 stuck relay
Bad relay on the circuit board will require a new circuit board.
Rod
US Parts Center
Apr 17, 2013 | Pool & Spa
Hot tub wont come on
What do you mean "Jump it"?
Check with a meter, ACROSS both hot wires to get a reading of 220-240 volts. do not test across 1 hot and the meter lead on ground! You probably are not getting proper voltage to the hot tub. Or you may have a burned system fuse normally 20-25-or 30 amp fuse, which is found within the control box of the spa.
Jan 06, 2013 | Balboa Instruments Duplex Digital Panel 2...
LocF error on hydroquip 9000 e spa
possible bad pump motor or relay to pump or shorted heater element
Oct 21, 2012 | Hydro Quip Inc Pool & Spa
Nov 16, 2011 | Hydro Quip Inc Pool & Spa
Unlock control panel
Press & Hold the JET Button for 6 seconds (Most/Gecko & Hydro-Quip)
or
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
Apr 16, 2011 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a hot tub with three bad motors. The
It's very unusual that 3 motors would go bad at the same time. I'd be more inclined to suspect the controls. Also, it's possible that if the unit is supplied by 240 volts that you may have lost one leg. Losing one leg could still enable the controls, since they are usually 120 volt, but none of the motors would run if they are 240 volt.
You can disconnect the motors and try to run them from a temporary line, too. Might save you some $.
Dec 30, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Just bought a house with a hydro quip cs 6000
Hey Mike; what is it you would like to know about your hot tub?
Thx
Ken
Aug 30, 2009 | Home
Hot tub wiring
this has nothing to do with computer speakers. it is a hot tub wiring problem...
Jun 22, 2008 | Audio Players & Recorders
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
