Question about Dyson DC40 Animal Upright Vacuum - Self-Adjusting Cleaner Head Include
Dc40 sole plate won't sit flat to the floor - Dyson DC40 Animal Upright Vacuum - Self-Adjusting Cleaner Head Include
2 Suggested Answers
  • 64 Answers
SOURCE: how do i get to the motor
it is probably a hex head screw.
Posted on Nov 01, 2009
Tip
Dyson DC40 / DC42 - Getting started
<div><utube src="Spo8itk_chY"></utube><br></div>How to assemble and use your new Dyson DC40 or DC42 vacuum cleaner.
on Aug 19, 2013 | Dyson DC40 Multi Floor Upright Vacuum
The floor brush on my dyson DC40. As come unscrewed om ome side I've tried screwing it back in but it won't stay in
The plastic it screws into is stripped. Fill the hole with quick set Epoxy and install the screw before it set completely..
Oct 11, 2016 | Dyson DC40 Multi-floor Vacuum DC40
My Dyson works perfectly well with the base plate. As soon as i use the hose part it tends to loose all power and i cant even stretch the hose properlu
The hose is blocked, so you have very little suction at the end. The vacuum in the hose is pulling the hose shorter. With the vacuum turned off, push a broom handle through the hose to dislodge the blockage.
May 11, 2016 | Dyson DC40 Multi-floor Vacuum DC40
HOW DO I TAKE APART MY DYSON
Hi there, it's Jack at Dyson.
I'm not sure from your question which aspect of your Dyson DC40 you want to take apart. However, please be aware that dismantling your machine any further than is shown in the User guide can void your Dyson guarantee, so we strongly advise against this.
If you're having difficulty with your DC40, you should be able to resolve this quickly and easily following the simple troubleshooting checks shown in our Support pages. Just select the menu option that's relevant to your issue: http://www.dyson.co.uk/support/dc40/dc40-multi-floor
If you would like some further help or advice from our experts, you're welcome to give the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or replacement part is needed, we can also confirm whether this is covered under your Dyson guarantee.
Feb 19, 2015 | Dyson DC40 Multi Floor Upright Vacuum
Dc 42 not sucking
Dyson Upright Animal Model DC 42 lost power head rotation. Took apart floor plate and also switch assembly. The switch assembly has two springs of which one fell out before we could determine how to put together. Does any one have an image of the spring locations in the switch assembly?
Jan 23, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Model DC40, the wand doesn't have any suction when I want to use on stairs, etc.
If your DC40 doesn't seem to have suction through the wand but picks up as normal on flooring, it's likely there's a blockage in the wand or hose. To locate and remove any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc40/dc40-multi-floor/my-machine-is-not-working/machine-not-sucking-up-well/check-the-wand-and-hosedc40
It's also worth giving both filters a wash as shown in the video below - in normal use this should be done at least once a month. Use cold water without detergent and at least 24 hours for the filters to dry completely before replacing them.
I hope this helps, but if you'd like any further assistance please call our freephone Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC18 all floors Bagless Upright...
When i set the floor setting to carpet, it makes a nasty rattling noise. doesn't do it on bare floor setting
There is one major difference between the hard floor setting and the carpet setting - the brushbar doesn't spin on the hard floor setting. Hopefully this is a simple problem - the rattling noise suggests there may be something trapped behind the brush rollers. You can inspect this by removing the sole plate from the vacuum. Doing this may allow any trapped objects to fall out without need for any further inspection:
To remove the sole plate:
1. Lie the dyson on it's side so you can access the underside or sit on a chair, turn the vacuum upside down and hold it between your knees.
2. Using a coin or a large flat-bladed screwdriver undo the two yellow fasteners on either side of the "sole plate" which covers the brush rollers.
3. Pivot the back edge of the sole plate upwards and remove it
Any loose debris can now be easily removed, While the sole plate is removed, it is a good opportunity to inspect the brushes and remove anything else that may be stuck to it.
Replacing the sole plate is the exact reverse of the removal process. Before replacing the sole plate, ensure that the brush bar is correctly and fully inserted.
There are other possible reason for the rattling noise, but your description leads me to believe that this should cure the fault. Inspect the brushbar first and then post back if you need further assistance.
Regards,
BElectric
Dec 15, 2010 | Dyson DC33 Bagged Upright Vacuum
Belt
Hi.
If its not all floors machine just turn the three plastic screws under the machine to unlock .
lift off sole plate remove brush roller fit new belt over brush roller then stretch belt over motor drive shaft.
Replace sole plate turn 3 screws to lock position & thats it.
If your machine has a clutch unit & is all floors type this is more harder to do & will need a lot of explaining so try this site for Dyson Service Manuals.
http://dysonmanuals.inc.io/
Chris.
Dec 02, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC40 Animal Upright Vacuum - Self-Adjusting Cleaner Head Include Logo
42 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
