Canon pixma mx 390 error 5012 - Office Equipment & Supplies
wayneard
  • 1901 Answers
SOURCE: replacing cartridges in canon pixma mx 310
Go to this page:
MX310 Support
Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
Thanks for using Fixya.
Posted on Mar 30, 2009
mace1mace
  • 1138 Answers
SOURCE: canon pixma mx 320 error 5800
there are two ways you can remove the error message from your printer..
the first is to reset the printer and the second is to replace the waste ink absorber. If the reset thing did not work for your then you'll be spending money to replace the absorber.
How to reset? follow these steps
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
Hope that solve the waste ink absorber in your printer..
Posted on Aug 04, 2010
  • 5103 Answers
SOURCE: have a 5100 error on
There are a few issues that cause a 5100 error code. 1) The encoding strip may need cleaning. 2) There is a paper jam. 3) The printer may need to be reset by turning it on and off. 4) The ink tanks may need to be properly snapped into their carrier. 5) The printer may need service.
The solutions to try
1) Cleaning the encoder strip. Use a cotton swab and isopropanol (rubbing alcohol) or window cleaner. A flashlight will help you see any grease on the encoding strip. With the printer on, open the printer by lifting the scanner unit until it locks. Unplug the power cord from the printer and wait until the LEDs are no longer lit. At this point you will be able to slide the cartridge carrier back and forth. To start, slide the carrier to the right. Look for the clear plastic strip (the encoding strip) in front of the carriage drive belt and look for any grease or other dirt on the strip. Remove the grease with a cotton wab moistened with the isopropanol. Look at the strip from several angles to check for any grease along the entire strip. Make sure you do not remove the grease from the chassis (metal rail). Move the cartridge carrier to the left and check the right side of the strip. When all of the grease is removed, lift the scanner unit support and close the unit. Plug in the power cord and turn the unit back on. Often grease gets on the encoder strip when you remove a paper jam. If you proceed to the next step, you may have to repeat this cleaning.
2) A paper jam
Carefully pull any sheet from the rear tray or paper output slot. Detach the rear cover and fully extend the rear tray support and try to pull the paper out slowly. Otherwise try turning the printer off and on - the sheet may be ejected. Remove the paper cassette and pull any paper out slowly that is in the front area. If needed, try removing the paper cassette and any paper in the rear tray. Then turn off the printer and unplug it. Set the unit upright on the left side and try to pull the paper out. Return the printer to the usual position when done. Replace the cassette, plug in the power cord and then turn on the printer. This will delete any documents in the printer queue. Check for foreign objects around the paper output slot. Remove any foreign objects with the unit off. Close the rear cover completely. Make sure that the paper isn't curled up.
3) Turn the unit off, unplug the power cord and wait 10 seconds or longer. Plug in the power cord and press the On button. Wait until the printer completes the cycling process before trying to print again.
4) Verify that the ink tanks are properly seated. With the printer on, lift the scanning unit up until it locks. Press on the black circle on each ink tank until it snaps firmly into place. Check if the ink lamps light up red. Make sure the protective shipping covers was removed from the ink tanks. If the unit has the remaining ink level detection feature disabled, replace the ink tanks. Close the scanning unit.
5) If none of the above solutions work, contact Canon if the unit is under warranty. Otherwise, decide if the service is worthwhile for an out-of-warranty printer.
I hope this helps.
If the paper tears when you try to remove it, open the scanning unit with the printer on and unplug the printer. Then look for and remove the paper. Use a flashlight to check for paper and other foreign objects in the corners. Slide the cartridge carrier back and forth to check the corners completely.
For pictures check the support site: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx860#ServiceAndSupport . Search for the error code 5100 and then follow the links.
Posted on Jan 09, 2011
SOURCE: initial setup printer error has
Canon MX340 Error 5011
Posted on Jun 08, 2011
  • 3278 Answers
SOURCE: canon mg5250 error code 5012...what
Hello.
That error indicates a error occurred in the scanner flatbed motor. The solution is to replace the Scanner unit.
Your printer would need to be serviced. Evaluate to see if cost-effective for repair.
If your printer is still under warranty, return to Canon for repair / replacement.
Hope this helps.
Posted on Jul 02, 2011
Printer error 5012
Hello, this is from the service manual
22 times Flatbed motor error
[5012] (1) Flatbed motor flexible cable connection:
-> Re-connect the cable.
(2) If the error still occurs:
-> Replace the part(s) listed on the right (under
"Parts to be replaced if the listed solutions are
not effective").
-Scanner unit with the flatbed motor cable
Jul 28, 2014 | Canon Pixma MX452
Help me Please ..!! i want to reset my Canon Pixma e500 series
hi folks. joana here....Please help me. I've encountered an error code with my canon e500 series namely P22. while trying to resolve it by print test, Error 5012 suddenly popped up.. I don't know what to do.. please help
Nov 04, 2012 | Office Equipment & Supplies
Canon pixma mx 700 won't scan showing error code 0x00000015
This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
If you have lost it you may download new drivers from here
http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
Aug 16, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX 308
How to reset canon MX 308 ??
Error Code 5800
Any Software to reseter this printer?
Feb 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Open Questions:
157 people viewed this question
k24674
