Question about Cadence ZRS-C4 - 1800W Peak 4-Channel Class A/B ZRS Type C Series Hi
Channels 1 & 2 suddenly stopped working.
There was a light pop and then high frequency sound on front left but none on front right. Now there is no sound from either front speaker.
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
Hope this helps!
BASS-OUT
sources.
SML).
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
Car Audio - mixed ohm speakes - best setup
Here is the link how the speakers are suppose to be connected.
http://www.fixya.com/Uploads/images/94A2E8C.jpg
You notice how they hook it up the left connections are your full range or hi frequency speakers and the switch is on for HPF (High pass Filter meaning only high frequency is being passed thru)
The right connections are connected to subs and the switch is on for LPF (Low pass Filter meaning only low frequency is being passed thru)
If you turn off these switches to off the its FULL RANGE all frequencies will pass thru.
The single output of the radio is probably for a subwoofer output but since your using the amp to power speakers too Its useless because your sending only low frequencies to the amp which will make any speakers connected to the amp sound horrible due too all the highs and mids will be filtered out.
STEP 1. 2 4ohm speakers depending where you put them Front or back. Hook these speakers up to the Radio's speaker wires coming out of the radio harness. You can also call them Hi level output wires FR & FL wires if positioning them in the Front. Hook them to the RL or RR if positioning them in the Back. What ever wires you dont use tape them SEPARATELY . DO NOT TAPE THEM TOGETHER and cause them to touch each other it will short out the radio and you will hear no sound.
STEP 2. Ok get 4 same length speaker wires and cut them long enough to go too the amp. Now these speaker wires will only send the FULL RANGE frequency signals to your amp. So note with a paper and pen how your connecting each speaker wire. I would tape one wire with black tape to remember this is the FR right, 2 tape FR left, 3 tape BK right, 4 tape Bk left. And I would make the copper thread of the wire positive and silver thread of the wire negative (very important so that your in phase and it will sound awesome) mixing up the positive and negatives will give you a tinney sound and it horrible to hear .
STEP 3 connect these 4 speaker wires to the High level out speaker wires coming out of the radio. The wires that are already connected to the 2 4ohm speakers go ahead and splice into them and the ones you didnt use connect to the remaining 2/4 speakers. REMEMBER OR NOTE THE CONNECTIONS cause you have to connect the right sequence and right polarity + & - to the HI Level input of the AMP. You will not use any RCA'S from the radio to the amp anymore. Since your radio dont have any Front & Rear output coming from the back of the radio. (YOU CANNOT USE BOTH RCA INPUT & HI LEVEL INPUT OF THE AMP ITS 1 or the other OR YOU WILL BURN OUT THE AMP AND DAMAGE THE RADIO)
STEP 4. Now connect your 2 6ohm speakers of your front left and back left together in parallel and your 2 6ohm speakers of your front right and back right together in parallel. Look at the diagram hook it on the left connections as in the picture of the front left speaker(but your connecting two 6ohms valued at 3ohms when in parallel and the amp can handle 2ohms so its safe) Do the same connection for your two right speakers as shown in the diagram of the Front right speaker. SWITCH THE HPF to OFF so that you get full range out of your speakers. Mid range is 70% of your music if you turn it ON you are only getting the high frequencies and it will sound awful.
STEP 5. This is the final connection Your 6 ohm sub is very bad for this amp. For example if you bridge it off of the last two channels the amp may double the power. If each channel is 100 watts and you connect the positive to one channels positive and connect the negative to the others channel negative(presuming its bridgeable) On a regular 4ohm sub it will be getting 200 Watts of power which is an average thump. Now you put a 6 ohm sub it will be weak and it will be getting around 130Watts. To make it worse if this 4 Channel amp is not bridgeable you can only connect it to 1 channel and the output will be around 70 WATTS causing distortion due to lack of power. If you still connect the sub be sure the switch is ON.
Good luck cause this the best connection you can do anything different and I'm sorry it will sound even worse. I am a master installer and have done this for 12 yrs. The higher the ohms the worse the sound gets cause less power. Thats why car speakers are 4ohms and home speakers are 6 ohms or higher cause they have a bigger amplifier to power and 120volts AC current. A car only has a 12Volt DC current powering the amp.
Apr 06, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
The light comes on but little sound comes out
theres a chance you may have blown up the amp. never put a sub that is to strong for the amp because its pushing all of the energy out of the amp to power up the sub, causing the amp to blow a fuse or the channels, on the back there is control of frequency turn everything all the way up to see if you can even get it to thump hard but dont blow your sub if it pops turn down some stuff and check the head unit to where its fading to the front or rear and balance to left or right
Jul 27, 2009 | Legacy LA1478 Car Amp
Both front power windows stopped working
hope this helps. if u have any other questions just let me know
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1 - Headlight, Low Beam, Left (56b) 10
2 - Headlight, Low Beam, Right (56b) 10
3 - License Plate Lights (5icon_cool.gif 10
4 - Rear Window Wiper And Washer System 15
5 - Windshield Wiper/Washer 15
6 - Fresh Air Blower, A/C (X) 20
7 - Tail Lights, Right (58R) 10
8 - Tail Lights, Left (58L) 10
9 - Rear Window Defogger 20
10 - Fog Lights 15
11 - Headlight, High Beam, Left (56a) 10
12 - Headlight, High Beam, Right (56a) 10
13 - Horn (15) 10
14 - Back-Up Lights 10
15 - Engine Electronics (15) 10
16 - Power Sunroof, Front Map/Reading Light 15
17 - Emergency Flashers (15) 10
18 - Fuel Pump (FP), Heated Oxygen Sensor (HO2S)
Control Module 20
19 - Coolant Fan, A/C Relay (30) 30
20 - Brake Lights (30) 10
21 - Interior Lights, Clock, Luggage Compartment
Light (30) 15
22 - Cigarette Lighter, Radio, Luggage Compartment
Release 10
Separate Fuses
(Located above the relays)
- Fuse for ABS hydraulic pump relay 30
- Fuse for ABS main relay 30
- Fuse for A/C 30
- Fuse for power windows 20
- Fuse for cruise control 5
- Fuse for cigarette lighter 15
May 20, 2009 | 1997 Volkswagen Jetta
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
No sound from Front Speaker
take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Mar 02, 2007 | Mission 700 Main / Stereo Speaker
Cadence ZRS-C4 - 1800W Peak 4-Channel Class A/B ZRS Type C Series Hi Logo
42 people viewed this question
Top Cadence Car Audio & Video Experts
xxxxxx xxx
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
